Hi
I am wanting to build a PC box that will sit next to my TV and stream from PLEX or even use PotPlayer for Video Playback
The aim is to handle playback for 4K 10-Bit HEVC.
I am looking at this CPU and Motherboard
HTML Code:http://www.aperturepc.co.za/product/asus-h110m-r-ddr4-micro-atxWould this be good enough hardware?HTML Code:http://www.aperturepc.co.za/product/intel-kabylake-s-lga1151-pentium-g4600-dual-corehyper-threading-4-threads-3-6ghz-box-cpu__trashed
	The Pentium G4600 has Intel HD 630 graphics, which are good enough for decoding 4K 10-Bit HEVC video with Pot Player, but your motherboard lacks the proper connections for 2160p output at more than 30Hz as well as HDR support. A motherboard with HDMI 2.0a would be better for connecting the PC with a UHD TV. DisplayPort 1.2 would work for connecting a 4K monitor.
 Only a small percentage of motherboards have an HDMI 2.0a port. None of them is MATX form factor. (I know this because I'm looking for a MATX board with HDMI 2.0a myself.) Motherboards with HDMI 2.0a are all either Mini-ITX or ATX. See http://forum.blu-ray.com/showpost.php?p=13271422&postcount=108
 So, you need a different motherboard or a suitable video card. An MSI Geforce GT 1030 2G LP OC or MSI GeForce GT 1030 2GH LP OC would be good low-power consumption, low cost cards for what you want to do.Last edited by usually_quiet; 20th Jan 2018 at 12:31. Ignore list: hello_hello, tried, TechLord, Snoopy329
	That's awesome feedback, just perfect
 I'll run the board and CPU for now, and 2/3 months down the line get a GFX card in
  RX 480 isn't capable of decoding HEVC 4K 60fps 4:4:4By nesvariigi in forum Software PlayingReplies: 2Last Post: 7th Dec 2016, 21:00
  HEVC Hardware Decoding/EncodingBy jmdale1984 in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2015, 23:58
  Queries on HEVC encoding and decoding errorsBy ironurn in forum Video ConversionReplies: 1Last Post: 16th Jul 2015, 03:34
  Questions regarding WPP in HEVC decodingBy Rosh in forum Video ConversionReplies: 3Last Post: 1st Apr 2015, 00:22
  The newest LAV filters has hardware HEVC decoding support.By Stears555 in forum Software PlayingReplies: 13Last Post: 1st Oct 2014, 18:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
