I want to remove two sections of https://www.rte.ie/player/ie/show/prime-time-30003251/10827949/ without reencode. It is flv container. I understand Avidemux will but if where i want to cut is not a key frame will i be left with a messy edit, a part of something i don't want?
Avidemux gives only FLV1 and VP6 supported for video. If saved as avi or mkv is that reencode?
I will be doing this regularly as the programs often have twor or more issues and I will only want one What would be the best program?
Is Main@L3.1 the codec? i though AVC was h264
General
Complete name : C:\Users\DavidB\Prime Time-Kerry Babies.flv
Format : Flash Video
File size : 516 MiB
Duration : 34 min 28 s
Overall bit rate : 2 092 kb/s
_type : 708
_data : AAAAYN///ICA/YCA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AA A+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+AAA+ AAA+AAA+AAA+AAA+AAA/w==
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 7
Bit rate mode : Variable
Maximum bit rate : 1 995 kb/s
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color range : Limited
Audio
Format : AAC
Format profile : HE-AAC / LC
Codec ID : 10
Duration : 34 min 27 s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz / 22.05 kHz
Frame rate : 21.533 FPS (1024 spf)
Compression mode : Lossy
Yes.
You can set video to "copy" and choose e.g. mkv container and it will not re-encode but it will only cut on I-Frames then.
If you want to be able to cut arbitrarily but without re-encoding the whole file you can try other softwares like e.g. SolveigMM Video Splitter. This topic comes up quite often so you should be able to find more recommendations via a forum search.
AVC is indeed H.264. "Main" is the H.264 "profile" and "3.1" is the H.264 "level". -
Did MultiAVCHD reencode my video?
By ezcapper in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2016, 11:50 -
Is it possible to adjust contrast or brightness without reencode
By ConanEdogawa in forum Newbie / General discussionsReplies: 13Last Post: 28th May 2015, 09:11 -
MKV (h264) from 4:3 to 16:9 no reencode
By shorto in forum Video ConversionReplies: 7Last Post: 15th Jan 2015, 09:49 -
Help to ProRes > crop/scale > FLV in one step? MPEG Streamclip tov FLV help
By cleantones in forum Video ConversionReplies: 10Last Post: 20th Sep 2013, 15:04 -
reencode with different audio track
By zoranb in forum MacReplies: 2Last Post: 1st Aug 2013, 17:21
