hi
i have used dvdstyler on several dvd home player ,but select title doesn't work
i have these settings , can somebody tell me what's wrong
1) I select new project
2) after i select
3) the menu 1 and 2 are here
button 1 & 2
well i burn the dvd , and when i insert in the dvd home tv player or blue ray home tv player -> select title doesn't work
may i know why?
i have burned dvd under windows 10 and high sierra , but when i put the dvd in the dvd player , the select select title doesn't work
the select title settings are
please don't be angry for the many screenshots but i spent 1 day to try to let it work
i have tried toaster mydvd in high sierra but it doesn't work it doesn't burn the dvd ,on imac i have an external samsung dvd burner i own a SAMSUNG TSST Ultra-Slim Optical 8X DVD Rewriter Drives SE-218GN/RSBD, M-Disc support, MAC OS X compatible
thanks
thanks
Your post show a star for title 2 indicating somethings wrong.
[Attachment 44439 - Click to enlarge]
And in my opinion: the more info the betterplease don't be angry for the many screenshots
I can't tell from your post what's wrong with your second title but maybe attaching the file dvdstyler.log found in your temp may shed some light on this.
[Attachment 44440 - Click to enlarge] -
hi
well i want to thank you very much
i gave a look to the log , under mac it was not very easy to find it ,just because i'm mostly a windows user , i have use finder it's an macos utility and it's free
i guess i found the issue , i created a dvd and now it works
the weird thing is that i have used toaster (there is mydvd) , it works but it doesn't want to burn the dvd
do you think just because on an imac i update from sierra to high sierra?
just because toaster worked perfectly under yosemite and el capitan
about toaster i got the last version
thanks
Did DVDStyler ever work on Macs?
By MovingParts in forum MacReplies: 16Last Post: 2nd Oct 2015, 19:06 -
DVDStyler - Having problems with chapters and playback in final Title
By nobodyhome in forum Authoring (DVD)Replies: 0Last Post: 30th Jun 2014, 14:51 -
Problems with subtitles in DVDStyler
By john1973 in forum Authoring (DVD)Replies: 7Last Post: 17th Mar 2014, 23:35 -
DVDStyler v2.3 ERR: Cannot jump to chapter 3 of title 1, only 2 exist
By rewt in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2013, 16:04 -
DVDStyler Transcoding Problems
By RBCC in forum Authoring (DVD)Replies: 5Last Post: 27th May 2013, 08:51
