Hi,
I want to buy a region free dvd-player (or easily modified).
Could you give me advice about which are not too expensive, good and available in Canada? And that can plays NTSC and PAL.
Thank you very much!![]()
The DVD player rejects the wrong region. The television rejects the wrong video format(PAL).
Theoretically all DVD players can play both NTSC and PAL....things sometimes go wrong on the OTHER end of the video cable.
Unfortunately you are about 10 years too late to find an abundance of inexpensive, good quality region free players that can also convert PAL to NTSC before it hits the television.
Not impossible, but nowhere as easy as it used to be. -
You might try an internet search for: 220-electronics.com . They have region free players.
Get a cheap media player (an old second-hand WD Live would work), then rip the disk to a hard drive or USB (using freely available free software) and plug it in.
That should play NTSC or PAL files, and the region coding will be irrelevant. It shouldn't cost more than a good DVD player.
You are more likely to have issues with whether your TV can handle the output than region coding per se, as I gather many TVs sold in the US/Canada don't support both PAL and NTSC input. Mercifully, that hasn't been the case here for about a decade.
AEG 4542 DVD player region free
By Marco_4124 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Feb 2016, 05:26 -
Region Free or 1 for DVD Player Mitsui 1559
By chuybarrera7 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Nov 2013, 13:52 -
Good economic region free dvd player
By Gorkat in forum DVD & Blu-ray PlayersReplies: 16Last Post: 22nd Jun 2013, 11:37 -
sony dvd player SR500H region free
By asra in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Jun 2013, 22:45 -
Sony dvp-sr310p dvd player region free
By newm in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Feb 2013, 22:06
