Hi,
I'm using the PRO version of VSDC and I'm having difficulties trying to put a fade out effect within a photo timelapse (sprite)
The photo timelapse is contained in a sprite. Then I just insert a video effect -> fade out, but it simply doesn't work. I've tried to put this sprite into another sprite and try to add the fade out outside the sprite, still no good.
Can anyone help me? Anyone tried to use a video effect in a photo timelapse?
Thanks!
Here is a method that works for me:
- Click on the Sprite
- In the Properties window, look for the "Sprite object settings" section.
- Set 'Use as container' to No
- Set 'Show effects' to Yes
You can now right click on your Sprite to add the 'fade out' effect. I am using version 6.3.6.18 and I have to move up the 'fade out' effect using the layer controls to have it show-up correctly. -
I was having the same problem and took your advice, but it didn't work. When I selected NO to container
, a black screen came up
Editing a sprite
By aligray in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2017, 14:37 -
XMEDIA RECODE video converter FADE IN / FADE OUT
By vinckles in forum Video ConversionReplies: 6Last Post: 11th Aug 2017, 02:10 -
FFMPEG - fade in logo independent of fade in video and subtitles
By EasyFeet in forum EditingReplies: 2Last Post: 16th May 2017, 01:59 -
How to Fade In/Fade Out Audio Clips in VSDC Free Video Editor?
By BSquared18 in forum EditingReplies: 15Last Post: 6th Mar 2015, 22:44 -
Fade in and fade out an mp4
By loninappleton in forum EditingReplies: 29Last Post: 21st Jan 2015, 13:17
