How do I finalize a dvd made on this machine? It plays fine, but only on this machine. I can't find a menu to finalize it. The manual says it will play in other machines when it's finalized, but it doesn't tell you how. Thanks,
mm
I had the same problem and used this solution.
https://forum.videohelp.com/threads/357242-dvd-r-did-not-finalize-properly-now-cannot-...sk#post2252626 -
If you are looking for instructions on how to finalize DVDs recorded by your Toshiba DR570KU using the normal process provided by the machine itself, download a PDF copy of the user's guide here: https://support.toshiba.com/support/modelHome?freeText=2805105 then read page 16.
The instructions I wrote in that old thread linked to in the previous post are for situations where data on an unfinalized disc must be recovered because finalization failed or the DVD was never finalized and the DVD recorder that made the disc is either dead or not in your possession.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks. I found the finalization instructions in the playback section of the book. Logical, yes? I don't think so.
Finalize DVD-R, is this possible?
By chiyoaiki in forum DVD & Blu-ray RecordersReplies: 35Last Post: 19th Dec 2016, 13:49 -
How to finalize cd/dvd without the original recorder
By davethewave152 in forum AudioReplies: 1Last Post: 17th Feb 2014, 00:48 -
dvd+r did not finalize properly now cannot access disk
By matey in forum Software PlayingReplies: 5Last Post: 7th Jul 2013, 05:09 -
Finalize DVDRW+ ??
By clumb31 in forum MediaReplies: 9Last Post: 17th Mar 2013, 03:50 -
Toshiba DR570KU went crazy
By johnsees in forum DVD & Blu-ray RecordersReplies: 9Last Post: 25th Feb 2013, 23:00
