  1. I am capturing at 480 X 576 I would like to encode as MPEG 2 and burn as SVCD on to a single disc, I have tried the bitrate calc and Fit cd but the pics always come out blocky even set to multipass vbr, any other way of fitting it, The file is 2 hrs long when Tmpeg with normal mci file it comes out 2.6 gig.
    Mar 2002
    cleveland/cincinnati
    yeh right... 2 gig file on a cd-rom
  3. 2 hours of video on one CD-R...that's an average bitrate of about 890k/sec; that's not a lot of data to spread across 480x480. At twice that average bitrate, you'd likely still see a fair amount of visible macroblocks.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. Dman,
    It depends on the quality and source of your capture. The cleaner the source is the better it will compress. You can get two hours of movie at 480 x Y, with the right template. If your source was say dvd, no prob. I've done a few svcd's, complaint, 480x480, hitting the 799 to 802mb mark. Some recent dvd's will come out with very very nice quality. Some i've done rivaled cce 3 pass {two discs} using tmpgenc 2.53, and have fit on one cd. The last project was a capture at dvd resolution from an older vhs tape. It compress very nicely, with very good quality {for a vhs capture that is} on two cd's. When i ran a second encode to fit it on one cdr, there were few tiny blockz here and there, and it wasnt as sharp as the same encode on a two cdr-svcd set.
    If you want to stick to svcd try one of the templates from schizzon, or the Scissors' templates: http://forum.vcdhelp.com/viewtopic.php?t=81201&start=0
    for svcd.
    For Xvcd
    try Berrantus. http://www.geocities.com/berrantus/ <---i havent tested these yet.
    or Kwag'z.
    Kwags templates will let you do two hours in mpg1 vbr, rivaling svcd quality, but you can tweak the video settings to 480 x 480, or 352x240{from the default 352x480} or leave it a 352x480 half dvd, you player may play this setting and display it properly , (as opposed to windows media player which will show it at 353x480).
    ZtR
  5. hi
    you can also try for 1 disc(90min CD-R,2h movie)encoding 352x288(240) mpg2 VBR eg. 2 pass Avg 900-min 500-max 1450 with CCE ,
    this is not a legal SVCD format but my standalone player does not care , good results whith Anime by using this Matrix settings
    (i havn't tried them with Tmpeg)
    Anime Matrix Intra
    . 8,16,17,19,22,26,31,37,
    16,17,19,22,26,31,37,44,
    17,19,22,26,31,37,44,53,
    19,22,26,31,37,44,53,63,
    22,26,31,37,44,53,63,74,
    26,31,37,44,53,63,74,85,
    31,37,44,53,63,74,85,96,
    37,44,53,63,74,85,96,99
    NonInta1
    16,32,33,35,38,42,47,53,
    32,33,35,38,42,47,53,62,
    33,35,38,42,47,53,62,72,
    35,38,42,47,53,62,72,83,
    38,42,47,53,62,72,83,95,
    42,47,53,62,72,83,95,99,
    47,53,62,72,83,95,99,99,
    53,62,72,83,95,99,99,99
    cheers
