Hi everyone,
I have a PAL Format Videotape of home movies that I would like to transfer to DVD. I am in the USA so I know everything is NTSC (TVs/VCRs/DVD players)
I currently have a PAL camcorder (Sanyo VMD-66P) that I can hook up to my Dazzle DVC100 capture card and transfer the tape to my computer using the Pinnacle software. Not the best quality, but it will get the job done this time.
The tape plays the movie but it is in black and white with horrible horizontal lines through the picture (Will post a picture later) The Dazzle Pinnacle software reads the camcorder footage but the output is in black and white, same as the camcorder.
I have a SCART to AV cable that can plug into the camcorder to a VCR but have no idea where to find A SCART supported VCR. My option, if I do this myself, seems to be to find a PAL supported USB capture card. Does anyone have recommendations on what to possibly purchase? I have 5 tapes.
Thank you
Results 1 to 14 of 14
Not familiar with capture device but I have had a quick read of the manual.
Assuming you are using the capture software that came with the device - the manual discusses MovieStar 5 - you must set a broadcast standard from the project profile dialog. Obviously this must be PAL (you might have yours preset for NTSC if you have used it before).
Scart connections are only found on UK and European VCRs. Even if you outsource one of those you will still have the NTSC issue that has to be addressed in the capture software.
There is another potential issue. Several analog capture devices do not work beyond WinXP. You do not state your OS but if it works for a NTSC tape then you can discount this remark. -
One other thing I forgot to mention.
Let's assume that your capture was correctly done as PAL and you created a PAL DVD. That may still not display on a standard US tv. The best you can do is convert that PAL capture to NTSC and create a NTSC dvd. -
SCART to anything adapters almost never work as you think.
Honestly, if you have just 1 PAL Video8 tape, outsource it to a professional for quick process.Want my help? Ask here! (not via PM!)
Thank you for the reply. I have a total of 5 tapes. Being in the USA, the SCART cable is no use to me. Couldn't I run AV cables from the camcorder through a PAL/NTSC converter to a capture card or from the camcorder through a PAL supported captured card?
I am using a Windows 7 64-Bit HP Laptop.
I was planning on looking into AM CAP. -
You need to set up your hardware and software as PAL.....capture the tape to your computer as PAL.
Just get it to your computer in color first and foremost.....worry about NTSC next. -
That's my top priority right now. I've got the Pinnacle capture software set to PAL already. The tape playing on the camcorder (standalone and hooked into my laptop), as black and white with those horizontal lines. Not sure if I'm missing a step, just hoping it's not a tape issue.
I think we also need to see a sample of the raw capture (not some youtube conversion etc.)
It could be the camcorder and not the capture process. -
Once again, have you actually used this capture device under Win7-64 ?
and are you absolutely certain that the camcorder is playing a PAL output ie PAL-B/G and not PAL-M or something similar(which is closer to NTSC than European PAL) and that the tape is also PAL-B/G
There does appear to be significant timing errors here which is why I ask about the tape and how it was recorded. Same camcorder ? -
Well Romania was PAL-D/K which, it seems, is quite similar to PAL-B/G but not exact
Romania, it appears, never used SECAM or its East European variants.
Now if the camcorder that shot the video was targeted for the Romanian market there would have to be some modification since the normal practice would be to connect the camcorder to a tv for direct viewing.
Most capture software does provide for these variants but you still have to select the right one. But if the camcorder was not the model that shot the video you may be wasting your time and just bite the bullet and put the tapes out to professional sources that can handle world broadcast systems. -
I recently had zero issue playing Romanian PAL tapes in JVC HR-S7965EK deck captured with ATI AIW cards set to PAL I/B/G/etc.
How to capture PAL G tape and image stabilization?
By digicube in forum Capturing and VCRReplies: 13Last Post: 29th Jul 2017, 11:49 -
VHS Tape (PAL) to DVD or the Best Format Conversion/Restoration Guide
By ConverterCrazy in forum RestorationReplies: 5Last Post: 18th Jun 2017, 22:33 -
VID clips from video tape onto dvd
By lovebug in forum Newbie / General discussionsReplies: 10Last Post: 10th May 2017, 01:29 -
PAL tape capture - color issue
By nesburf in forum Capturing and VCRReplies: 3Last Post: 3rd Mar 2017, 12:41 -
VHS Video Test Pattern Tape (PAL)
By VHSRules in forum Capturing and VCRReplies: 2Last Post: 4th Mar 2016, 11:05
