I capture motorcycle races with the Elgato Game Capture HD in 720p 60fps. I use just about the highest bitrate. I have tried to check the x264 settings of the captured video with video help but it doesn't list them. I then take out the commercials and encode it with MeGUI. How do I figure out what settings are overkill vs the source other than the eye test? I think I am using overkill settings just to be safe. I would like the encode to go faster if possible.
Results 1 to 11 of 11
The usual way to figure out the best encoding settings is to encode the same 10-15 seconds with half a dozen settings. You then watch them all and choose the one that is the best compromise of quality vs. settings. This tradeoff also includes how long it takes to do the encode.
There is no magic bullet or one-size-fits-all answer: you just do the work and look at the result. -
You can use --psnr or --ssim in x264 to get objective metrics. But those metrics don't match human perception of video quality very well.
Use CRF 1pass encoding, especially encoding game footage, because bitrate demand can fluctuate rapidly. To guess average bitrate is almost not possible. Even if you do it correctly by some miracle, then there is another capture and you will be off again, searching for optimal bitrate , yet again.
Use CRF encoding mode encoding to quality, not bitrate. So you just need to find out your CRF number that looks good for you. Then you just use that number all the time. Start with CRF 18. Lower number produces better quality but file size gets bigger. Or if you increase that number, quality drops a bit and filesize a bit as well.
It is counter intuitive to presume that encoder can watch the quality. But it does. It compares to the original and that is actually you asked for. So you can let encoder do that.Last edited by _Al_; 17th Jan 2018 at 13:21.
Do your best capturing, best what your device can do, and then , if you must (VideoRedo would cut scenes out etc. without re-compression), encode use CRF method for encoding, for any content. There is millions of people still encoding to a bitrate even if they do not have to. There is just tons of tutorials that uses it on web, it is out there, it is difficult to get rid of that consensus from past. Talking about H.264 encoding with x264. Some encoders, different codecs work differently. Or if there is no way around, like maybe your device that perhaps can capture only to a certain pre-sets, based on bitrate.
Another concern is interlacing. Does that Elgato deinterlaces a content if your content is interlaced? FOX channel broadcasts progressive 60p, I think, but others might not.Last edited by _Al_; 17th Jan 2018 at 16:55.
Elgato Game Capture HD probably does not use x264 but instead a codec that's compatible with the H.264 encoding chip that it probably has. Hardware encoding is not as efficient per byte as x264 but hardware encoding can be more energy efficient, free up CPU demand, and make devices cheaper. I have never used this device but it might have Slow/Medium/Fast options that you might be able to toggle.
The Elgato Game Capture HD uses a hardware h.264 encoder. As with all hardware encoders, it's less efficient than x264 (except maybe at the ultrafast and superfast presets)
Best x264 settings that you've ever tried
By anana in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2016, 00:13 -
Trying to cut a clip out of a video (AVC/x264) & can't figure it out; help?
By CuttingClips in forum Newbie / General discussionsReplies: 5Last Post: 31st Jan 2016, 19:13 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 02:14 -
What is the best settings for x264
By mmkk in forum Video ConversionReplies: 7Last Post: 14th May 2014, 12:11 -
MEGUI + x264 settings
By Cunhambebe in forum Video ConversionReplies: 41Last Post: 18th Apr 2014, 06:14
