Howdy! This seems like it shouldn't be too hard, but I can't seem to find an easy way to do it...
I have a bunch of xvid encoded avi files with dual audio tracks, and the wrong, foreign-language track is set to default. I'd like to remove the primary audio track to reduce storage space, as well as save the user the hassle of re-selecting the secondary audio track on every file.
Essentially, i'd love an AVI version of MKVToolNix GUI - probably one of my favorite little programs ever! If you're not familiar, you pop in a file, and are shown all the streams. You select the ones you want and with one click, it'll remux the selected streams into new files, but only outputs MKV. is there an AVI equivalent that's just as easy to use??
Thanks!
AnonymousGuest
Give a try to AVI-Mux GUI.
It still should work great with most .AVIs. Sadly it does not support the most-recent Matroska files because it hasn't been updated anymore. -
VirtualDubMod:
File -> Open Video File
Video -> Direct Stream Copy (remux only, no encoding)
Streams -> Stream List, highlight the track you don't want, press Disable, close dialog
File -> Save As... new AVI
How to remove TS stream text and menu?
By dashimo in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2017, 02:07 -
How i can remove or replace logo in video stream with FFmpeg
By sarjukhe in forum Video Streaming DownloadingReplies: 5Last Post: 26th Mar 2017, 21:28 -
How can I stream h264 files with FFmpeg over rtmp without reencoding?
By Ninelpienel in forum Video Streaming DownloadingReplies: 4Last Post: 11th Mar 2016, 12:47 -
batch remove the last 30 seconds of mkv files without reencoding?
By alc112 in forum EditingReplies: 5Last Post: 5th Oct 2014, 15:46 -
SWF to FLV without reencoding (direct stream copy)
By Stears555 in forum Video ConversionReplies: 2Last Post: 10th Nov 2013, 19:03
