Results 1 to 10 of 10
  1. Hi.
    I'm new.
    I need to remux video file 4k HVEC (10 bit and h265 codec) m2ts.
    tsmuxer doesn't work with them.
    Could you suggest me another propgram to remux this kind of file and extract only a few number of audio tracks?
    Sorry in advance for my basic english
    regards.
    USA
    Probably better asked and answered in our Mac Forum. Moving you.
    And welcome to our forums
    Moderator redwudz
  3. ....thank you very much.....
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Have you tried ffmpeg (command line tool) or ffWorks, one of the GUIs for ffmpeg?
    That should work for muxing. [Not UHD BD authoring though, which I think no consumer software can do (yet).]
  5. I’ll try it. Thanks for you kindly help
  6. Doesn't work.
    ......could you suggest me another chances?
    Thanks in advance
  7. Anonymous
    Guest
    Originally Posted by grendelcat View Post
    Doesn't work.
    Please define "doesn't work".
    Because any recent version of ffmpeg should support muxing+demuxing+decoding of 10-bit HEVC streams
    https://ffmpeg.zeranoe.com/builds/macos64/static/?C=M&O=D
  8. Originally Posted by Marsia Mariner View Post
    Doesn't work.
    hi i'm not able to install the program. i downloaded from your link but i've not .dmg file
    thanks in advance for your help
    Aug 2006
    off the purple line
    Ts muxer should work. Change the extension to .TS and then see if it will work. After you remux, if you need .mts then change back to .mts.
    Also, there are some Korean extensions you need to remove from the library to make TS Muxer work.
    http://forum.selur.de/topic366-info-tsmuxer-will-not-work-due-to-on-mac-os-x-systems.html
  10. Originally Posted by danielmak View Post
    I’ll try as you suggest. Thanks for you kindly help
