for example I downloaded some film, it is somehow encoded with some program, when I try to use ffmpeg to convert it, let's say from mkv to mp4, i get an error that:
[matroska,webm @ 0x1d06640] Read error at pos. 2241497 (0x2233d9)
now how can I know where is the reason that this happens? should just avoid this kind of files, or somehow debug it and see what is the reason behind this error? or maybe skip this error frames, but i dont know how many frames may be like this, what if most of the file is filled with corrupted frames, altough it is playable in the video player
You can try to force ffmpeg to ignore errors - add bellow to your commandline
I would advise to reencode your source so output will have corrupted content but will be correct from syntax perspective.Code:-err_detect ignore_err -ec guess_mvs+deblock+favor_inter -ignore_unknown
after trying this commands:
after converting the output video, the file size is too low and it just stops while playing at some point and thats it,Code:[matroska,webm @ 0x1789580] Read error at pos. 2241497 (0x2233d9) [h264 @ 0x28aaee0] error while decoding MB 45 33, bytestream -11 [h264 @ 0x28aaee0] concealing 964 DC, 964 AC, 964 MV errors in B frame frame= 191 fps= 18 q=-1.0 Lsize= 934kB time=00:43:40.12 bitrate= 2.9kbits/s video:558kB audio:372kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.478487% [libx264 @ 0x17d5720] frame I:3 Avg QP:14.47 size: 8780 [libx264 @ 0x17d5720] frame P:99 Avg QP:17.68 size: 5154 [libx264 @ 0x17d5720] frame B:89 Avg QP:14.18 size: 381 [libx264 @ 0x17d5720] consecutive B-frames: 33.0% 14.7% 0.0% 52.4% [libx264 @ 0x17d5720] mb I I16..4: 51.4% 44.1% 4.5% [libx264 @ 0x17d5720] mb P I16..4: 2.9% 6.8% 0.1% P16..4: 23.0% 3.1% 3.1% 0.0% 0.0% skip:61.0% [libx264 @ 0x17d5720] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 5.0% 0.1% 0.0% direct: 0.1% skip:94.7% L0:39.8% L1:58.6% BI: 1.6% [libx264 @ 0x17d5720] 8x8 transform intra:63.4% inter:85.2% [libx264 @ 0x17d5720] coded y,uvDC,uvAC intra: 20.2% 24.4% 4.2% inter: 5.0% 6.7% 0.2% [libx264 @ 0x17d5720] i16 v,h,dc,p: 59% 20% 10% 11% [libx264 @ 0x17d5720] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 13% 53% 2% 2% 2% 2% 1% 1% [libx264 @ 0x17d5720] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 40% 19% 22% 4% 5% 3% 4% 2% 2% [libx264 @ 0x17d5720] i8c dc,h,v,p: 80% 10% 9% 0% [libx264 @ 0x17d5720] Weighted P-Frames: Y:21.2% UV:18.2% [libx264 @ 0x17d5720] ref P L0: 56.8% 13.1% 20.7% 8.4% 1.1% [libx264 @ 0x17d5720] ref B L0: 79.9% 17.9% 2.2% [libx264 @ 0x17d5720] kb/s:1.74
I've tried to reencode it to the same container mkv, but got the same errors
tried to reencode wit this command:
output:Code:ffmpeg -err_detect ignore_err -ec guess_mvs+deblock+favor_inter -i "film.mkv" -c:v libx265 -preset ultrafast -x265-params lossless=1 test.mkv
Code:[matroska,webm @ 0x1e94ba0] Read error at pos. 2241497 (0x2233d9) [h264 @ 0x2853500] error while decoding MB 45 33, bytestream -11 [h264 @ 0x2853500] concealing 964 DC, 964 AC, 964 MV errors in B frame [matroska @ 0x1efe6c0] Starting new cluster due to timestampitrate= 0.2kbits/s frame= 191 fps= 17 q=0.0 Lsize= 18850kB time=00:43:40.11 bitrate= 58.9kbits/s video:18664kB audio:172kB subtitle:0kB other streams:0kB global headers:8kB muxing overhead: 0.074325% x265 [info]: frame I: 1, Avg QP:4.00 kb/s: 230.17 x265 [info]: frame P: 48, Avg QP:4.00 kb/s: 21305.16 x265 [info]: frame B: 142, Avg QP:4.00 kb/s: 18611.59 x265 [info]: consecutive B-frames: 2.0% 2.0% 0.0% 95.9% x265 [info]: lossless compression ratio 9.21::1 encoded 191 frames in 11.48s (16.63 fps), 19192.27 kb/s, Avg QP:4.00
how should I correctly reencode it?, cause even ignoring errors wouldn't help
video source info by the way:
Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Bit rate : 4 000 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23,976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 148 r2721 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x132 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=239 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=69 / qpstep=4 / vbv_maxrate=8000 / vbv_bufsize=17500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=3:1.00 Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 DURATION : 00:44:08.693000000
IMHO, quite obviously your video source is defect, and ffmpeg is unable to decode beyond this point, so it seems to be a larger corruption.
Different decoders have a different "error resilience"; if ffmpeg can't skip the corrupt part safely, maybe other applications (VLC player - yes, it can convert too; Avidemux) or some AviSynth decoders can (FFMS2, L-SMASH Works, DSS2Mod with LAV Filters, and DirectShowSource as the last hope). -
I was using Handbrake and Format Factory back in a day for that. You can also try WALTR if you wanna watch the movie on Apple devices.
Life isn't about finding yourself. Life is about creating yourself. -
Please note the warning that Format Factory may mess up your system by installing "Possibly Unwanted Programs" (ad-supported freeware).
Dealing with OPUS audio of MP4/WEBM/MKV
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2017, 02:36 -
Using FFMPEG how do I convert an entire folder of webm files to wav or mp3?
By alphainventions in forum Video ConversionReplies: 1Last Post: 7th Aug 2016, 20:56 -
FFmpeg error message when converting MKV to MP4
By BigPhil1 in forum Video ConversionReplies: 1Last Post: 15th Jun 2016, 15:59 -
FFmpeg error trying to convert audio in mp4
By Thunderhead2772 in forum Video ConversionReplies: 4Last Post: 30th Jan 2015, 10:24 -
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 06:35
