I got virtual dub and a codec from my friend which he uses all the time and has no problems. i went to use it the other day to encode a file to .avi and ever sicne then all i get this is error.
VirtualDub Error
Error initializing audio stream compression:
The requested conversion is not possible.
That pops up each time i hit save as avi...ive asked a few people and no one has had this problem...im beginning to wonder if it is a hardware problem or something?
ive tryed encodin the exact same file as my freind yet his works and mine i get this error...we have all the same settings to.
if anyone has ever seen this or knows what the problem is please help me out either reply here or send me a e-mail
( Bass_Player69@hotmail.com )
i really want to get this to work so i can cahgne soem files to avi and with the codec i got... i dotn think its a codec prob because my freind is using the exact same stuff....but any help will be appreciated.
Try changing to audio. Goto Auido and put it on Full process mode. Then goto audio then Compression, Put it on PCM (uncompress). If you want to make it smaller you can use a different compression like Mpeg layer 3., But i'll use PCM just to make sure it works. Then Goto Audio then conversion, then put it on 41,000 or 48,000. 8 bit, stereo. Now click ok, and try to save the .avi. Oh yea and on the video put it on Direct stream copy)
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
