Hi everyone.
Should somebodody help me with changing region code in Sony DVP-SR310P ? I can't find hacks... And my kids can't see movies from Europe.![]()
If you have more than a few discs, it would probably be worthwhile to get an Android Box for less than $50. Then rip your DVDs and play them off a flash or external hard drive. Gets around NTSC/PAL playback issues and it's more convenient and cost effective than having to rip and burn the DVDs to new discs.
Thanks for fast answer.
You right , that is good idea, but unfortunatelly I've over 100 dvd's.
And my wife planning to buy more...
It's why I am looking for codes. -
But how, I must ask, will you deal with the PAL issue ?
Making your player region free will still not make them playable on US tv's -
No hacks for that cheap and cheerful model. No hacks for ANY sony model. You've got two separate problems: region code and, as DB83 said, analogue color system (NTSC/PAL), which have to be both dealt with (assuming you got a bog standard north american-bought TV that WILL NOT display anything through its HDMI or analogue ports that is 25 or 50i/p (as European DVDs will wont to be)). Some Philips DVD players do have an NTSC/PAL conversion choice in the setup (though they will remain region 1, unless hacked or "reprogrammed", such as https://www.amazon.ca/Philips-Region-Free-DVD-Player/dp/B004BI6MVS)...
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
As has been stated, there is no region-free code for your player. If by chance you've seen or heard of your player being region-free it's software and/or software was modified by a technician or company.
Your options are:
As mentioned above, get a player that does internal PAL to NTSC and find a region-free code for it. Note that region-free codes for current DVD players are extremely rare and are usually for non North American versions and subject to change with new revisions of existing models.
Get a pre-modified player. www.220-electronics.com been around a long time and has a good reputation. Make sure to get one that specifies playback on ALL TVs or NTSC to PAL output.
Rip and burn your DVDs to new discs and use a player that does PAL to NTSC conversion
Rip and playback your DVDs on an Android Box or other local media / streaming device.
Note that with Blu-Ray players the first option isn't available at all since all region-free Blu-Ray players are software and/or hardware modified.
Sony DVP-NS55P
By Charles6898 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2017, 19:48 -
Hack for Sony DVP-SR170
By trekker2u in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Feb 2016, 11:38 -
Difference between Sony DVP-SR760HP and Philips DVP 3688/94 DVD Players
By sanyalps in forum Authoring (DVD)Replies: 0Last Post: 28th Dec 2014, 05:44 -
DVP-SR510H Sony DVD Player.
By lahav in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Aug 2013, 09:19 -
Sony dvp-sr310p dvd player region free
By newm in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Feb 2013, 21:06
