I'm trying to playback the Elephant Dreams png images using mplayer.
Using:
I get:Code:"G:\Hybrid\64bit\mplayer.exe" -v mf://"H:/sequence/ED-360-png/*.png" -mf type=png:fps=25:w=640:h=480 -forcedsubsonly -nosub -noautosub -fps 25.000 -vo direct3d -lavdopts threads=8 -mc 0 -nosound
Code:MPlayer SVN-r38010-7.2.0 (C) 2000-2017 MPlayer Team CPU vendor name: AuthenticAMD max cpuid level: 13 CPU: AMD Ryzen 7 1800X Eight-Core Processor (Family: 23, Model: 1, Stepping: 1) extended cpuid-level: 31 extended cache-info: 33579328 Detected cache-line size is 64 bytes CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNowExt: 0 SSE: 1 SSE2: 1 SSE3: 1 SSSE3: 1 SSE4: 1 SSE4.2: 1 AVX: 1 Compiled with runtime CPU detection. get_path('codecs.conf') -> 'G:/Hybrid/64bit/mplayer/codecs.conf' Reading optional codecs config file G:/Hybrid/64bit/mplayer/codecs.conf: No such file or directory Reading optional codecs config file /local64/etc/mplayer/codecs.conf: No such file or directory Using built-in default codecs.conf. init_freetype Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay get_path('fonts') -> 'G:/Hybrid/64bit/mplayer/fonts' Configuration: --prefix=/local64 --bindir=/local64/bin-video --cc=gcc --extra-cflags=-DPTW32_STATIC_LIB -O3 -std=gnu99 -DMODPLUG_STATIC --extra-libs=-llzma -liconv -lws2_32 -lpthread -lwinpthread -lpng -lwinmm --extra-ldflags=-Wl,--allow-multiple-definition --enable-static --enable-runtime-cpudetection --disable-gif --disable-cddb --disable-faac --disable-faac-lavc --with-dvdread-config=/mingw64/bin/pkg-config --static dvdread --with-freetype-config=/mingw64/bin/pkg-config --static freetype2 --with-dvdnav-config=/mingw64/bin/pkg-config --static dvdnav CommandLine: '-v' 'mf://H:/sequence/ED-360-png/*.png' '-mf' 'type=png:fps=25:w=640:h=480' '-forcedsubsonly' '-nosub' '-noautosub' '-fps' '25.000' '-vo' 'direct3d' '-lavdopts' 'threads=8' '-mc' '0' '-nosound' Using Windows native timing get_path('input.conf') -> 'G:/Hybrid/64bit/mplayer/input.conf' Reading optional input config file G:/Hybrid/64bit/mplayer/input.conf: No such file or directory Reading optional input config file /local64/etc/mplayer/input.conf: No such file or directory Falling back on default (hardcoded) input config get_path('*.png.conf') -> 'G:/Hybrid/64bit/mplayer/*.png.conf' Playing mf://H:/sequence/ED-360-png/*.png. WINSOCK2 init: 0 STREAM: [mf] mf://H:/sequence/ED-360-png/*.png STREAM: Description: Multiple files input STREAM: Author: Benjamin Zores, Albeu STREAM: Comment: MF file format detected. [mf] search expr: H:/sequence/ED-360-png/*.png [mf] number of files: 15691 (125528) ==> Found video stream: 0 VIDEO: [MPNG] 640x480 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:16 fourcc:0x474E504D size:640x480 fps:25.000 ftime:=0.0400 <vo_direct3d>Setting backbuffer dimensions to (5120x2880). <vo_direct3d>device_caps_power2_only 0, device_caps_square_only 0 <vo_direct3d>device_texture_sys 0 <vo_direct3d>max_texture_width 16384, max_texture_height 16384 vo: win32: running at 5120x2880 with depth 32 ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 58.8.100 (internal) Configuration: --enable-gpl --enable-postproc INFO: libavcodec init OK! Selected video codec: [ffpng] vfm: ffmpeg (FFmpeg PNG) ========================================================================== Audio: no sound Freeing 0 unused audio chunks. FPS forced to be 25.000 (ftime: 0.040). Starting playback... ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 EOF code: 1 Uninit video: ffmpeg WINSOCK2 uninit <vo_direct3d>uninit called. <vo_direct3d>uninit_d3d called. <vo_direct3d>destroy_d3d_surfaces called. <vo_direct3d>Stopping Direct3D. vo: win32: uninit Exiting... (End of file)
Does anyone know what I'm doing wrong?
Cu Selur
It works here with a simple mplayer "mf://[PATH]/*.png". Did you also try without all the other parameters? Does mplayer work for "normal" video files?
/edit:
Ok, peculiar behavior: it only works if I have the png's folder as the working directory.Last edited by sneaker; 13th Jan 2018 at 05:33.
Without the '-mf type=png:fps=25:w=640:h=480' it doesn't work either,..
without '-mf ..':
Code:STREAM: [mf] mf://H:/sequence/ED-360-png/*.png STREAM: Description: Multiple files input STREAM: Author: Benjamin Zores, Albeu STREAM: Comment: MF file format detected. [mf] search expr: H:/sequence/ED-360-png/*.png [mf] number of files: 15691 (125528) MPlayer interrupted by signal 11 in module: demux_open - MPlayer crashed by bad usage of CPU/FPU/RAM. Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash. - MPlayer crashed. This shouldn't happen. It can be a bug in the MPlayer code _or_ in your drivers _or_ in your gcc version. If you think it's MPlayer's fault, please read DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and won't help unless you provide this information when reporting a possible bug.
Code:Playing mf://H:/sequence/ED-360-png/*.png. WINSOCK2 init: 0 STREAM: [mf] mf://H:/sequence/ED-360-png/*.png STREAM: Description: Multiple files input STREAM: Author: Benjamin Zores, Albeu STREAM: Comment: MF file format detected. [mf] search expr: H:/sequence/ED-360-png/*.png [mf] number of files: 15691 (125528) ==> Found video stream: 0 VIDEO: [MPNG] 0x0 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:16 fourcc:0x474E504D size:0x0 fps:25.000 ftime:=0.0400 <vo_direct3d>Setting backbuffer dimensions to (5120x2880). <vo_direct3d>device_caps_power2_only 0, device_caps_square_only 0 <vo_direct3d>device_texture_sys 0 <vo_direct3d>max_texture_width 16384, max_texture_height 16384 vo: win32: running at 5120x2880 with depth 32 ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 58.8.100 (internal) Configuration: --enable-gpl --enable-postproc INFO: libavcodec init OK! Selected video codec: [ffpng] vfm: ffmpeg (FFmpeg PNG) ========================================================================== Audio: no sound Freeing 0 unused audio chunks. FPS forced to be 25.000 (ftime: 0.040). Starting playback... ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 ds_fill_buffer: EOF reached (stream: video) V: 0.0 0/ 0 ??% ??% ??,?% 0 0 EOF code: 1 Uninit video: ffmpeg WINSOCK2 uninit
Code:"G:\Hybrid\64bit\mplayer.exe" "h:\1.m2ts" -forcedsubsonly -nosub -noautosub -fps 25.000 -vo direct3d -lavdopts threads=8 -mc 0 -nosound
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Nice, find! Works here too if I set the working directory to the image folder and then call:
Code:"G:\Hybrid\64bit\mplayer.exe" -v mf://*.png -mf type=png:fps=25:w=640:h=480 -forcedsubsonly -nosub -noautosub -fps 25.000 -vo direct3d -lavdopts threads=8 -mc 0 -nosound
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Virtualdub will not import image sequence...now what?
By Ikejohn in forum Newbie / General discussionsReplies: 18Last Post: 23rd Sep 2015, 19:38 -
Image sequence into video - Codec nightmare, help please!
By heihei in forum Newbie / General discussionsReplies: 8Last Post: 6th Sep 2015, 18:48 -
Pulling an image sequence from a video file
By greycobalt in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2014, 08:30 -
Batch save image sequence as PNG/JPG
By vasticles in forum Newbie / General discussionsReplies: 8Last Post: 27th Jun 2013, 23:22 -
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 08:37
