the nightly release does the same thing
here is the error message:
Problem signature:
Problem Event Name: APPCRASH
Application Name: HandBrake.exe
Application Version: 1.0.7.0
Application Timestamp: 58ea9d2f
Fault Module Name: ntdll.dll
Fault Module Version: 6.3.9600.18821
Fault Module Timestamp: 59ba86db
Exception Code: c0000005
Exception Offset: 00000000000356cc
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 4b67
Additional Information 2: 4b67410fe6afcfff9ac242a258cbf30a
Additional Information 3: c6fc
Additional Information 4: c6fc07e72d9535cff16aa47b03f0c40c
can anyone help?
AnonymousGuest
This is a core part of Windows so maybe your problem lies in your Windows install?
Does it crash immediately or when it runs a while? -
On the bug tracker there are some similar reports, some related to the OpenCL resizer. Turn it off (video settings) and/or try latest nightly build (OpenCL resizer has been removed from nightly).
https://github.com/HandBrake/HandBrake/issues/1091 -
HandBrake 1.0.7 (2017040900) - 64bit
OS: Microsoft Windows NT 10.0.17120.0 - 64bit
CPU: AMD A6-9220 RADEON R4, 5 COMPUTE CORES 2C+3G
Ram: 3981 MB,
GPU Information:
AMD Radeon(TM) R4 Graphics - 22.19.180.1025
Screen: 1366x768
Temp Dir: W:\temp\
Install Dir: D:\Videos\editor\handbrake
Data Dir: C:\Users\jtm_7\AppData\Roaming\HandBrake Team\HandBrake\1.0.7.0
# Starting Encode ...
[09:10:37] hb_init: starting libhb thread
# Failed to start encoding ...
HandBrakeWPF.Exceptions.GeneralApplicationExceptio n: Exception of type 'HandBrakeWPF.Exceptions.GeneralApplicationExcepti on' was thrown.
at HandBrakeWPF.Services.Encode.EncodeBase.VerifyEnco deDestinationPath(EncodeTask task) in C:\HandBrake\hbworkspace\workspace\Release_Windows Gui64\HandBrake\win\CS\HandBrakeWPF\Services\Encod e\EncodeBase.cs:line 216
at HandBrakeWPF.Services.Encode.LibEncode.Start(Encod eTask task, HBConfiguration configuration) in C:\HandBrake\hbworkspace\workspace\Release_Windows Gui64\HandBrake\win\CS\HandBrakeWPF\Services\Encod e\LibEncode.cs:line 92
[10:54:52] hb_init: starting libhb thread
# Starting Scan ...
[10:54:52] CPU:
[10:54:52] - logical processor count: 2
[10:54:52] Intel Quick Sync Video support: no
[10:54:52] hb_scan: path=Z:\temp\Season 2, title_index=0
src/libbluray/disc/disc.c:352: error opening file BDMV\index.bdmv
src/libbluray/disc/disc.c:352: error opening file BDMV\BACKUP\index.bdmv
[10:54:52] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 5.0.1
libdvdread: Encrypted DVD support unavailable.
libdvdread: Can't open Z:\temp\Season 2 for reading
libdvdread: Device Z:\temp\Season 2 inaccessible, CSS authentication not available.
libdvdread
VDOpenFilePath:findDVDFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdread
VDOpenFilePath:findDVDFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[10:54:52] dvd: not a dvd - trying as a stream/file instead
[10:54:52] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 2 - The Iowa-Scuba.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 2 - The Iowa-Scuba.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf57.25.100
Duration: 00:58:45.24, start: 0.046440, bitrate: 832 kb/s
Stream #0:0(und): Video: h264 (High) [avc1 / 0x31637661]
yuv420p, 848x480 [PAR 1:1 DAR 53:30], 697 kb/s
25 fps, 12800 tbn (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) [mp4a / 0x6134706D]
44100 Hz, stereo, fltp, 128 kb/s (default)
Metadata:
handler_name : SoundHandler
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 3 - The Quadripartite.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 3 - The Quadripartite.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:50.88, start: 0.046440, bitrate: 832 kb/s
yuv420p, 848x480 [PAR 1:1 DAR 53:30], 698 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 1 - Alexander the Greater.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 1 - Alexander the Greater.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:21.68, start: 0.046440, bitrate: 833 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 10 - The Cherry Blossom.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 10 - The Cherry Blossom.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:18.64, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 11 - The Virtue.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 11 - The Virtue.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:29.44, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 12 - The Children's Day.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 12 - The Children's Day.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:30.60, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 14 - The Yukon.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 14 - The Yukon.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:22.56, start: 0.046440, bitrate: 831 kb/s
yuv420p, 848x480 [PAR 1:1 DAR 53:30], 696 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 16 - The Dippy Blonde.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 16 - The Dippy Blonde.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:25.80, start: 0.046440, bitrate: 831 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 17 - The Deadly Goddess.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 17 - The Deadly Goddess.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:34.24, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 18 - The Birds and the Bees.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 18 - The Birds and the Bees.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:30.36, start: 0.046440, bitrate: 833 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 19 - The Waverly Ring.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 19 - The Waverly Ring.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:30.00, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 2 - Alexander the Greater part ll.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 2 - Alexander the Greater part ll.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:22.32, start: 0.046440, bitrate: 833 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 20 - The Bridge of Lions.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 20 - The Bridge of Lions.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:33.08, start: 0.046440, bitrate: 831 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 21 - The Bridge of Lions ll.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 21 - The Bridge of Lions ll.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:31.44, start: 0.046440, bitrate: 831 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 22 - The Foreign Legion.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 22 - The Foreign Legion.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:25.88, start: 0.046440, bitrate: 833 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 23 - The Mooglow.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 23 - The Mooglow.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:49.56, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 3 - The Ultimate Computer.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 3 - The Ultimate Computer.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:01.68, start: 0.046440, bitrate: 831 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 4 - The Foxes and Hounds.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 4 - The Foxes and Hounds.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:27.40, start: 0.046440, bitrate: 831 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 5 - The Discotheque.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 5 - The Discotheque.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:26.64, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 6 - The Re-Collectors.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 6 - The Re-Collectors.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:10.64, start: 0.046440, bitrate: 833 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 7 - The Arabian.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 7 - The Arabian.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:22.24, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:53] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 8 - The Tigers Are Coming.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 8 - The Tigers Are Coming.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:31.28, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:54] batch: scanning Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 9.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 9.mp4':
Metadata:
major_brand : isom
minor_version : 512
Duration: 00:58:28.32, start: 0.046440, bitrate: 832 kb/s
Metadata:
Metadata:
[10:54:54] scan: decoding previews for title 1 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 2 - The Iowa-Scuba.mp4)
[10:54:54] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:54] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:54] scan: supported video decoders: avcodec qsv
[10:54:54] scan: decoding previews for title 2 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 1 E 3 - The Quadripartite.mp4)
[10:54:54] scan: decoding previews for title 3 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 1 - Alexander the Greater.mp4)
[10:54:55] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:55] scan: supported video decoders: avcodec qsv
[10:54:55] scan: decoding previews for title 4 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 10 - The Cherry Blossom.mp4)
[10:54:55] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:56] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:56] scan: supported video decoders: avcodec qsv
[10:54:56] scan: decoding previews for title 5 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 11 - The Virtue.mp4)
[10:54:56] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:56] scan: decoding previews for title 6 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 12 - The Children's Day.mp4)
[10:54:56] scan: decoding previews for title 7 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 14 - The Yukon.mp4)
[10:54:57] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:57] scan: supported video decoders: avcodec qsv
[10:54:57] scan: decoding previews for title 8 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 16 - The Dippy Blonde.mp4)
[10:54:57] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:58] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:58] scan: supported video decoders: avcodec qsv
[10:54:58] scan: decoding previews for title 9 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 17 - The Deadly Goddess.mp4)
[10:54:58] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:58] scan: decoding previews for title 10 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 18 - The Birds and the Bees.mp4)
[10:54:58] scan: decoding previews for title 11 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 19 - The Waverly Ring.mp4)
[10:54:59] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:54:59] scan: supported video decoders: avcodec qsv
[10:54:59] scan: decoding previews for title 12 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 2 - Alexander the Greater part ll.mp4)
[10:54:59] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:54:59] scan: decoding previews for title 13 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 20 - The Bridge of Lions.mp4)
[10:54:59] scan: decoding previews for title 14 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 21 - The Bridge of Lions ll.mp4)
[10:55:00] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:55:00] scan: supported video decoders: avcodec qsv
[10:55:00] scan: decoding previews for title 15 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 22 - The Foreign Legion.mp4)
[10:55:00] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:55:00] scan: decoding previews for title 16 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 23 - The Mooglow.mp4)
[10:55:01] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:55:01] scan: supported video decoders: avcodec qsv
[10:55:01] scan: decoding previews for title 17 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 3 - The Ultimate Computer.mp4)
[10:55:01] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:55:01] scan: decoding previews for title 18 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 4 - The Foxes and Hounds.mp4)
[10:55:02] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:55:02] scan: supported video decoders: avcodec qsv
[10:55:02] scan: decoding previews for title 19 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 5 - The Discotheque.mp4)
[10:55:02] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:55:02] scan: decoding previews for title 20 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 6 - The Re-Collectors.mp4)
[10:55:03] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:55:03] scan: supported video decoders: avcodec qsv
[10:55:03] scan: decoding previews for title 21 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 7 - The Arabian.mp4)
[10:55:03] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:55:03] scan: decoding previews for title 22 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 8 - The Tigers Are Coming.mp4)
[10:55:04] scan: 10 previews, 848x480, 25.000 fps, autocrop = 0/0/0/0, aspect 1.77:1, PAR 1:1
[10:55:04] scan: supported video decoders: avcodec qsv
[10:55:04] scan: decoding previews for title 23 (Z:\temp\Season 2\The Man from U.N.C.L.E. - S 2 E 9.mp4)
[10:55:04] scan: audio 0x1: aac, rate=44100Hz, bitrate=128000 Unknown (AAC) (2.0 ch)
[10:55:04] libhb: scan thread found 23 valid title(s)
# Scan Finished ...
I just sent the hANDBRAKE 1.0.7 log files it throws an error when I go to encode??? SHould i try an older version? Vidcoder? John
crazy Handbrake crashes solved
By Spoffo in forum DVD RippingReplies: 2Last Post: 5th Sep 2016, 01:20 -
mkvmerge gui crashes on start/won't start
By buck09 in forum Blu-ray RippingReplies: 7Last Post: 2nd Nov 2015, 00:43 -
FFMPEGX crashes each time i encode and put subtitles on a .mp4 video
By franckygoes in forum ffmpegX general discussionReplies: 3Last Post: 5th Sep 2013, 15:51 -
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 06:26 -
Handbrake crashes on startup
By sum_guy in forum Video ConversionReplies: 12Last Post: 21st Apr 2013, 11:22
