Hello everyone. I got a problem with aegisub, which I use for my job as translator.
I can't get it to highlight the lines which exceed the "characters per line" limit that I set. On the first installation those lines had a red background and were easy to spot, but since I changed PC and reinstalled aegisub, I can only see the problem from the small box on the top right of the editor, which makes the whole thing much less practical.
Any ideas?
Thanks.
	Because nobody answered you.
 Your software is 3 years old and no more developed. Have you try any other subtitle software, or what is genuine for software you are using that you don't try another?
 In last 3 years there was huge step in some subtitles (creation/modification/translation) software.
 Sorry not answered your question, just curious why still using it.
 Bernix
	Hi,
 it depends on your subtitles format. But long lines depending on character per second, or word per minutes, showing long lines pink to red, that all is for sure in Subtitle edit. It has very much features, Auto translate (very rough translation of course) Advanced tools for timing, Waveform (when generated, you see subtitles here and can shift them or adjust lenght of them according to visualized sound) and much much more.
 Bernix
  Help with AegisubBy ThePi7on in forum SubtitleReplies: 7Last Post: 19th Mar 2019, 21:14
  To long lines in subtitleBy suadnovic in forum SubtitleReplies: 2Last Post: 18th Jun 2017, 14:09
  Why won't Aegisub transform the framerates?By Kracov in forum SubtitleReplies: 5Last Post: 16th Aug 2016, 09:01
  Aegisub won't let me print "%"?By user115 in forum SubtitleReplies: 14Last Post: 26th Dec 2015, 18:35
  Scrolling under aegisubBy Patapin in forum SubtitleReplies: 0Last Post: 7th Dec 2013, 09:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
