Hi all,
I have a DVD burner and would like to create a 'best of' DVD-R with selected clips from my DVD library. Is there any way I can rip/edit/burn just selected scenes from DVD's and then burn them to a DVD-R, without incurring the degradation of re-encoding the clips back into mpeg2?
Any suggestions welcome,
Scav
If you're on a PC, use SmartRipper to rip by chapter, if your DVD is chaptered. Re-author your ripped chapters and add a new menu.
Thanks for the suggestion!
But what if the scene I want extract is less than a full chapter? Are there any methods for doing this? -
Is there a "rip by scene" option in SmartRipper now? I'm not sure, it's been awhile since I used it. Unless you're working with a carelessly authored DVD as your source, chapters are pretty short already (anywhere from 2 to 10 minutes) ... If you want a piece of a chapter, re-encoding it shouldn't take all that long. However, there may be other options in SmartRipper or other rippers I'm no longer aware of.
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:31 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
? Re-encoding Just Part of a Video
By Synetech in forum Video ConversionReplies: 12Last Post: 23rd Jan 2008, 02:27 -
Can't copy VOB file?
By Hedgie in forum Video ConversionReplies: 7Last Post: 22nd Oct 2007, 08:03
