Thread: What is the best codec??
  1. #1
    What is he best codec to get maximum compression without losing a lot of quality? It dosen't matter if i need to pay for it or not, I just need to know what it is and where to get it.
    Free Flying Soul liquid217's Avatar
    Feb 2002
    Posts
    895
    well its hard to define the "best" of anything. there are just too many factors. I generally capture with picvideo's mjpg codec. At the higher bitrates it preserves the picture very well. Another good codec is huffuv. It is a loss-less codec, meaning the picture is preserved bit by bit from the uncompressed version. you can think of it to what zip files do to data, as to what huffuv does to video. links to all of these codec's can be found under the tools link on the left-hand side of the page.
    Member
    Jan 2002
    State of Confusion
    Posts
    1,793
    Quote Originally Posted by El_Gringo23
    Can you be exact as to your definition of these two terms:
    1. "maximum"
    2. "a lot"
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    ok...how bout minimum loss of quality. for mgeg-1 movies also.
    Member zzyzzx's Avatar
    Baltimore, MD USA
    Posts
    3,072
    Try using Huffyvu first but if it takes up too much disk space or your computer drops frames while using it try something like Picvideo's MJPEG instead. I've used both and like both but will probably use MJPEG from now on because I can capture at a higher resoultion with MJPEG (480) vs only 240 with Huffyv. So I actually get a better quality picture using MJPEG even though it isn't lossless.
    No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Posts
    9,206
    I use Motion JPEG A. It looks great; however, the file size won't be as small as it could be.
  1. Replies: 3
    Last Post: 21st Jan 2011, 14:10
  2. Can Codec ID/Codec Hint make a difference on the video?
    By dzsoul in forum Video Conversion
    Last Post: 1st Jun 2009, 19:40
  3. Replies: 13
    Last Post: 4th Nov 2008, 09:41
  4. Dv Codec
    By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)
    Last Post: 15th May 2008, 13:10
  5. Codec
    By MosThaTeD in forum Newbie / General discussions
    Last Post: 13th Dec 2007, 21:17
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
