Hello.
I use an old card and software to digitize vhs tapes - Winfast PVR 2000. Which is still quite ok I guess, by means that the mpg files are correct and qualitative (as qualitative as vhs rip can be).
However, when I try to improve a bit the original mpg capture in Sony Vegas 14, the resulting m2t file has the audio out of sync (the beginning is ok but gets worse until the end).
Here are the orginal file and the improved file properties:
[Attachment 44367 - Click to enlarge]
Also here are the video files:
original vhs capture (mpeg):
https://www.youtube.com/watch?v=6XRwYXy98zg
enhanced file with audio issue:
https://www.youtube.com/watch?v=7B2thociVUk
Is there anything I can do to avoid this?
Many thanks!
Vlad
Here they are
[Attachment 44368 - Click to enlarge]
[Attachment 44369 - Click to enlarge]
Ignore those 4 seconds, when improving I deleted unwanted vhs content from the beginning and the end.
Thanks -
Unfortunately this is not text form... In view choose Text, it is important, this view isn't much informative.
Bernix -
Sorry, never used mediainfo. Here are the text formats:
ORIGINAL:
General
Complete name : E:\Temp\WinFast WorkArea\Video_0106-1154(CVBS)_Celelalte Cuvinte Rock 95.mpg
Format : MPEG-PS
File size : 947 MiB
Duration : 20 min 48 s
Overall bit rate : 6 364 kb/s
Writing library : ArcSoft MPEG-2 PAL
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Bit rate mode : Variable
Bit rate : 6 014 kb/s
Maximum bit rate : 7 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.580
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 895 MiB (94%)
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.470 System B, BT.470 System G
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 20 min 47 s
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : 455 ms
Stream size : 33.3 MiB (4%)
IMPROVED:
General
Complete name : E:\Temp\WinFast WorkArea\Video_0106-1154(CVBS)_Celelalte Cuvinte Rock 95.m2t
Format : MPEG-TS
Commercial name : HDV 720p
File size : 2.79 GiB
Duration : 20 min 44 s
Overall bit rate mode : Constant
Overall bit rate : 19.3 Mb/s
Maximum Overall bit rate : 19.7 Mb/s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format profile : Main@High 1440
Format settings : BVOP
Format settings, Matrix : Default
Format settings, GOP : Variable
Codec ID : 2
Bit rate : 17.9 Mb/s
Maximum bit rate : 18.3 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.778
GOP, Open/Closed : Closed
Stream size : 2.60 GiB (93%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Codec ID : 3
Bit rate : 384 kb/s
Stream size : 57.0 MiB (2%)
Menu
Menu ID : 1 (0x1)
List : 4098 (0x1002) (MPEG Audio) / 4096 (0x1000) (MPEG Video)
Maximum bit rate : 19850000 -
Since original video is in sync, I don't know why exported video is out of sync. It is usually when you capture video, there are some frames skipped, but your video source is o.k. I haven't a Vegas, so don't know how it handle audio. But probably during rendering some frames was skipped for me for unknown reason. If I get it right video is before audio at the end, it means there are less videoframes frames... But probably I made fool from myself...
Sorry probably some Vegas users helps you.
Bernix -
Seeing the original while editing?
By Querorz in forum EditingReplies: 4Last Post: 22nd Nov 2016, 12:12 -
HD PVR 2 Capture card has audio issues. Any solutions?
By super6646 in forum Capturing and VCRReplies: 0Last Post: 17th Aug 2016, 18:40 -
How to capture images from a DVD in original size?
By Nicky123 in forum Software PlayingReplies: 24Last Post: 15th Feb 2014, 17:49 -
Video Conversion / Editing Workflow Issues
By petjuli in forum Video ConversionReplies: 63Last Post: 14th Jan 2014, 03:18 -
Editing dvd while retaining original menus
By vcats in forum EditingReplies: 1Last Post: 30th Mar 2013, 17:58
