my avi will not convert with tmpgenc. it locks up after about 70%. i used divfix and it said i had one bad frame (something like 129400). what can i do to either delete this one frame or fix it so i can convert to vcd.
tia
If you still haven't found the answer to this question. Go to Nicky's Pages. He has a great How To on appending a file. I did it with Bad Boys and only I can tell where the fix is.
Oh, and you do the repair in Virtualdub.
possible bad frame prob with file from Panasonic miniDVD camera
By ronhud in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Apr 2012, 16:40 -
Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
By chindoo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2011, 19:51 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 19:07 -
TMPGEnc - bad frame problem
By psyklax in forum Video ConversionReplies: 5Last Post: 30th Jun 2007, 22:44 -
bad audio frame
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 14:37
