I am having this problem - I can encode a widescreen (letterboxed) SVCD, and my standalone DVD player plays it fine and with proper ratio, but it seems to chop off about 10% of the picture on all sides. The only way I could fix the problem was by shrinking the picture by 10%, by setting TMPGEnc's Video Arrange Method to "Center (custom size)" at 432 wide by whatever (depending on input AVI's size ratio), while keeping output at 480x480 (NTSC). Then I seem to see the whole picture, including black borders at top and bottom.
What is going on here? I have Pioneer DV-333 - don't know if this problem is specific to Pioneer DVD players, or is more common. Plays DVDs (including widesceen) perfectly.
Have not seen any discussion of this issue on this forum. Is there a better fix than what I came up with?
Thanks,
zizou108
http://forum.vcdhelp.com/viewtopic.php?t=76947
This phenomenon is called TV overscan. You do not see the whole SVCD framesize as well as you do not see the whole DVD framesize. That is quite OK, because a lot of commercial DVD's come with very crappy edges. But if you encode to a low-bitrate format like SVCD you have to take care to save as much bits as ever possible. So do not encode what you can not see. -
Truman,
Thanks - was not aware of the "overscan" term (or the problem). Thanks for the tip.
zizou108
tv screen cuts sides and bottom of pic..
By andie22 in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2011, 13:50 -
End of movie cuts off on PC + regular DVD player but not on Mac
By xwr321 in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2009, 12:18 -
HDTV Picture Cuts at the Top
By Nitro89 in forum Off topicReplies: 0Last Post: 21st Sep 2008, 15:03 -
I burn a DVD and then when played in a DVD player it cuts off after 50 mins
By uk_rose in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2008, 21:43 -
Sides of picture cut off on TV after AVI to DVD
By HavoK041 in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2007, 04:41
