I'm desperately trying to find an external (USB or FireWire) version of the Pioneer DVD-R writer, but have heard many comments that external versions do NOT work for one reason or another.
Would be grateful if anyone has something to contribute!
Thanks in advance: The MacMan
Hey There,
I just recently bought a DVR104 and I also bought a Pyro firewire hardrive enclosure for it (approx. $99), and hooked it up externally via the firewire port and it works like a charm, as a result I didn't have to rip out my DVD Rom drive or my CD burner, and you can turn it on and off at will, the enclosure comes with a built in fan so there shouldn't be heat issues, it was a breeze to hook up and Windows XP noticed the drive immediately. I've burned like 4 dvd's without a problem.
hope this helps,
StvP -
... and from a Mac perspective, I purchased and received this week the Pioneer 104 drive. I purchased the LaCie branded external version, direct from the manufacturer. I use an iMac G3. I have burned a few DVDs so far with no problems. I found a copy of DVDPlayer software that would fully install on my G3 (in OS X) so I can now watch DVD-Video on my computer! Admittedly I had to develop a work-around -- DVDPlayer doesnt recognize the external drive easily. So what I did was create a tiny DVD-Video image that I mount via Toast first. Mounting this image via Toast creates a "virtual" native DVD drive, which auto-launches the DVDPlayer app. Once the app gets launched by this DVD-Video image, I can then play other actual DVDs from the LaCie. Ripping DVDs does NOT require mounting a DVD-image first, though.
I'm shocked at how fast this thing burns a DVD at 1x! -
I saw this when I was looking for a good price on the A04.
http://www.esbuy.com/enclosures.html
They also sell the A04 with the enclosure.
Pioneer DVR 550 and external USB hard drive
By jackdup in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Jul 2010, 16:47 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
