I am trying to record from my capture card (WinTV) a movie from my dvd player that is plugged into it (through composite). I want to record to DivX with MPEG3 Sound. I try VirtuaDub, but it gives me a bluescreen error after some error about sound (see pictures). is there any other software I can use? After the Bluescreen error, my computer works really slow, and sometimes it restarts! If it does not restart, anything I do (like closing or opwning a new folder) will have purplish mess all over the screen where the folder was after I close it or on the icons of a new folder(again, see pictures). Any help is very appreciated!
More Info:
My Computer:
333 Celeron
256MB Ram
6.4Gig HDD
Software:
WinTV2000
VirtuaDub
DivX Codec 5.0
LAME MP3 Codec
I am trying to encode movie at 320X240, MP3 (22,000khz, stereo) sound, at 720kbps. 24bit RGB.
I am kinda new at this, but I have done my research and exhausteed all the sources on this site about this, thats why I am asking this question.
Pictures:
Syngori
www.consolevision.com/covers
Dreamcast DivX Beta 3 is out now!
I can highly recommend AVI_IO as a capturing alternative to VirtualDub. I too found VirtualDub unstable on my system. You can get AVI_IO at http://www.nct.ch/multimedia/avi_io/
If the problem persists you can try installing the latest drivers for your card or change the PCI slot where the card sits in your computer. -
Your PC specs are very low, I think perhaps your pc just is'nt up to it. Capturing directly to DivX is very CPU intensive. You could capture to AVI and convert to DivX, but you probrably dont have the hard disk space. If I were you I would start saving for a new PC.
Craig
Big audio problem
By gynno in forum AudioReplies: 6Last Post: 18th Feb 2012, 22:39 -
Big problem with Russian Subtitles
By Earthling2000 in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2011, 06:31 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 21:37 -
big problem with soundmax
By marlo in forum AudioReplies: 6Last Post: 23rd Jan 2010, 04:40 -
My first SATA hard drive looked lonely, so I got it another...
By Eldelli in forum ComputerReplies: 5Last Post: 25th Sep 2007, 22:21
