ok, ripping to dvd to [s]vcd following the guide.
Ripped ok, used dvd2avi ok [i think] then when i select the .d2v file for the video channel in TMPGEnc it says unsupported, am i missing something, have i installed a plug-in incorrect or missed one??
All this is confusing, first video i've tried.
Please can any 1 help me??
btw the .d2v was 400kb in size [hour and a half video][/url]
KNIGHTON MUST GO
checklist:
dvd2avi.vfp is in the same directory like dvd2avi.exe
TMPGEnc.vfp is in the same directory like TMPGEnc.exe
run TMPGENcVFP_INSTALL.bat
check TMPGEnc vfp is registered to VFAPI (TMPG>option)
check VFAPI plugin (dvd2avi>help)
TMPG> option> enviromental setting> VFAPI> check dvd2avi project file reader and/or select a higher priority.
Do not delete the .vob files. Do not move the .vob and / or .d2v unless you want to edit the .d2v manually. -
Cheers, increasing the priority solved it.Originally Posted by Truman
Many Thanks, till the next stage then
KNIGHTON MUST GO
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
.3GP File currupted o unsupported
By MikeDinner in forum EditingReplies: 2Last Post: 31st Mar 2009, 04:02 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
