    Jan 2018
    india
    i have a .ds2 audio file in folder "C:\test\abc.ds2"
    Sox installation folder is at "C:\Program Files\sox-14-4-2"
    How do I convert file abc.ds2 to .wav using command line ?
  2. afaik neither sox itself nor ffmpeg support ds2 audio atm. so you are probably out of luck,..
    Since you are on windows you could use 'DSS Player Lite for Windows' to convert those files to wav. (but it doesn't work through the command line)
