Hi!
I have a serious prolbem at hand here, ive just bought me 50
pack recordable discs so i can burn Brave Heart etc, i have splitted
em in two files and mpeged them with TMPgen.
But when i load em into Nero the file cheking goes ok but still
i cant get Nero to actually create the VCD:s, its simply says
invalid field parameter and could not preform start disc at once.
Its driving me mad cause ive suceeded before with the same software
and i have no clue what so ever how to fix it.
So if any one could suggest some help or mabe give me a hollor
on MSN ide pruciede it wery much.
//KnightHeart
Results 1 to 11 of 11
you might want to try to use VCDeasy or something like it to make an image of the VCD first, and then either mount the image with daemontools and do a disc copy, or just burn the image in Nero(under file)--either method should work...although using the daemon tools should be "foolproof"
--the only other thought I have is whether or not you have the "create standard compliant CD" checked(don't) -
Tnx for the reply =) im gonna try that last checkbox rigth now, one other thing also failed. I tried to make a regular audio cd but that also gave me same errors so i installed Easy CD Basic Edition wich came on the buy and proggy at least manages the audio discs so i dunno whats spooking with Nero but il try that checkbox first.Originally Posted by fantomlord
//KnightHeart -
What burner do you have? I suspect it's an HP/Philips, and either 4x or 6x write speed. Usually, that invalid field in... error is due to the writer not being able to write the small auido clips. How did you encode the audio in your VCDs? Just the regular template in TMPGEnc? That should be fine...also, try some different media, if possible. There's a chance that the media is to blame. You may also want to try a newer version of Nero.
Howdy!Originally Posted by brock4111
=) Actually it aint the burner is an new IDE NEC 72XX modell, when i make VCD:s from DivX movies etc i save the splitted files with avi audio and direct streem copy. And the version of Nero i have is 5.5.4.0.
I used the regular VCD NTSC templates in TMPgen and it has worked quit excellent on other movies i have made. -
I would suggest not splitting the audio and vidfeo. Just open TMPGEnc, and convert from divx to VCD directly. Then cut it into 2 files.
What speed is that writer, btw? -
Hmns i dont split it into audio and video i split em in two files with AVI video&audio, hmmm well if i VCD it directly without splitting then i would have to split em after the encoding or? unles there are some miracle template that reduces it to fit on a 800/900Mb CD.Originally Posted by brock4111
The CD writer handles from 4X to 16X. -
Ok hmn with TMPgen wont that just split the other half to AVI and the recompress it to mpg or am i nutts hehe =).Originally Posted by brock4111
Hmm, yeah, you are just nuts. j/k
Here's what you want to do. Open TMPGEnc, and close the project wizard. Then click open/browse (whichever it says, for where you click the video.) Browse to your movie, and open it. Click load, and choose the VCD (NTSC) setting. Click RUN.
Go to sleep at this point, because it will take HOURS!
When it's done, click file, mpg tools. Click the far right tab (merge and cut.) Click the drop-down box, and chose Video-CD. Click add, and choose the converted movie. Click the left curly brace, then move the slider to the middle of the movie, and click the right curly brace. Click ok. Type in a NEW name for the movie (brave1.mpg). Click run. This part will take about 3 minutes. See if this half will go into Nero. (make sure that the half isn't longer than 80 mins.) If it works (which it SHOULD), then use TMPGEnc to clip the second half, too. (Start the clip where the last one left off, and end it at the end of the movie) How long is Braveheart, and how many CDs are you putting it on? -
Howdy =)Originally Posted by brock4111
Well lers see know the complete size on the DivX is 686Mb large
and the playtime is 2 hours and 50 minutes, the mpegs i did get made
on that movie are about 800Mb large so they fit on one 90min CD each.
The computer i have has a 1.8GHz processor so it might not take spec
long to encode, those two clips where made on a three hours oncoding time om regular NTSC VCD template.
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 07:14 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 12:40 -
Problem Installing Nero 8
By ranchhand in forum ComputerReplies: 1Last Post: 10th Feb 2008, 22:20 -
Nero Problem
By alley04 in forum Authoring (VCD/SVCD)Replies: 3Last Post: 6th Sep 2007, 19:08 -
problem with Nero
By moe_b_disc in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2007, 06:13
