I am trying to find a way to patch a MPEG2 video file to run at 25 fps instead of 30 fps without re-encoding the file. Is that possible?
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
Yes, it is possible. Try ReStream to patch the sequence header. As usual you have to edit the audio seperately. Note that a header patching is no replacement for NTSC to PAL conversion. You can not resize that way. But if you selected just the wrong framerate accidentally and you want to correct it, this is the way to go.
Cool, that worked, but now I of course wonder: Can also the 3:2 pulldown be "patched away"?
God, how dumb I am. Of course... I could have used pulldown.exe all the way! Thanks anyway!
Audio track from 25fps video with a 23.976 fps video
By cedworld in forum AudioReplies: 12Last Post: 22nd Apr 2014, 09:31 -
Not Patching DTS
By Torontor in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 18:57 -
29.97fps subs to a 25fps Video?
By solrage in forum Authoring (DVD)Replies: 34Last Post: 1st Feb 2011, 21:16 -
Converting 25fps XVID to 29.97 MPEG2
By dkrajisnik in forum Video ConversionReplies: 6Last Post: 21st Sep 2010, 14:46 -
24fps HD-MKV (H264/VC-1) to 25fps SD-MPEG2
By Nightwalker_z in forum Video ConversionReplies: 9Last Post: 27th Apr 2009, 09:31
