Hi
Anyone know of a player that can play the files created in VCD toolbox without having to burn them to disc.
Zed
http://www.daemon-tools.com/daemon_tools.htm
this program makes a FAKE cd-rom in your machine so you jus load the image into the virtural cd drive and it will play or browse jus like if there was a cd in your computer wow!
hope that helps
F1!! F1!! F1!!! -
Yep that is a good program, thanks for the link however how do i go about using the file created with VCD toolbox with it??
Sorry if this sounds dumb but this is all new to me!
cheers
Zed -
What format does VCD toolbox spit out ?
the program i showed you can play .bin .cue files
it thinks its a vcd and plays it
so you dont have to burn the vcd first to test it out
F1!! F1!! F1!!! -
It creates a .CD file that you then load in to a program called TOCSPLT which then creates a .cue file and a track file. Unfortunately the .cue file is only useable in winoncd or gear and I only have gear, nero and ezcd5 and I can find no way to change the .CD file to an iso image - I would love to get this sorted out cause it will make doing my project so much easier.
Appreciate the help
Zed
Any product similar to the AV Toolbox AP-411 lip-sync corrector?
By svejkovat in forum AudioReplies: 3Last Post: 5th Feb 2012, 12:29 -
How do you automate DVRMS Toolbox
By Datahead in forum Media Center PC / MediaCentersReplies: 0Last Post: 3rd Nov 2007, 09:55 -
Free copy of AVI Toolbox today only (8-23-07)
By Solarjetman in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2007, 11:58 -
VCD to DVD with subs - subpictures below video-image - Help?!
By nbarzgar in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jun 2007, 10:44 -
AV Toolbox AVT-8710?
By hip_school_preppie in forum Capturing and VCRReplies: 4Last Post: 30th May 2007, 18:43
