the problem is the 5118 wdm drivers. If you are installing from scratch, install dx8.1 first, 6015 ati drivers (they include wdm drivers), uninstall 6015 display drivers, install 6048 ati drivers. I then install mmc 7.1, set custom avi profile for 640x480 huffy, regedit to 480x480, install 7.6 on top of 7.1.
You can also remove 7.1 (being sure to select yes when it ask if you want to save custom settings, then install 7.6.)
Remember, you might need the wmasf.dll and wmvcore.dll files if you uninstall 7.1, to get 7.6 tv to come on.
(this prevents you from having to install media player 7 to get tv to work)
If people want a quide, I will do one with screen shots of the regedit. If not, oh well. I hope this helps everybody, there seems to be alot of people having problems with this
Results 1 to 1 of 1
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Post deleted since I figured it out
By denise4gb in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2008, 23:29 -
Figured Out 'RATATOUILLE', menus and all
By theizzlesin2005 in forum DVD RippingReplies: 39Last Post: 11th Feb 2008, 09:48 -
Red Finally Begins Shipping 4K Res Camera
By Soopafresh in forum Latest Video NewsReplies: 3Last Post: 8th Sep 2007, 02:38 -
anyone figured out apocalypto yet?
By steamedPS in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 15:06
