Hi,
I'm converting a DVD to VCD using Sefy's great guide,but on this certain DVD after ripping and encoding it is missing the first 10 mins.Can anyone help?
Results 1 to 10 of 10
"The more sensitive you are, the more certain you are to be brutalized, develop scabs, never evolve. Never allow yourself to feel anything, because you always feel too much"
Marlon Brando -
How are you encoding ? if you are using Flask/DVDx then i suggest when you rip, that you use Files mode and not Movie mode.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi,thanks for the response :) I'm using TMPGEnc plus,I tried it out also on dup-dvd(it's crap i know) and it came up the same;Dvdx won't run on my pc it says it's missing a DSOUND.DLL 11 .The film is "Drawing Flies" btw.
jj"The more sensitive you are, the more certain you are to be brutalized, develop scabs, never evolve. Never allow yourself to feel anything, because you always feel too much"
Marlon Brando -
You are missing or you have an outdated DirectX, I suggest you update to the latest v8.1, you can download that from www.microsoft.com/directx
Did you rip your movie in files mode or movie mode ?Email me for faster replies!
Best Regards,
Sefy Levy,
Hi,again thanks for the reply.I ripped the film in the default settings,sorry I can't tell you which method.
JJ"The more sensitive you are, the more certain you are to be brutalized, develop scabs, never evolve. Never allow yourself to feel anything, because you always feel too much"
Marlon Brando -
The error you got from DVDx is regarding the DirectX, so I suggest you first install that to fix that problem.
Best Regards,
Sefy Levy,
Once again thanks I installed directx 8.1 and dvdx nows work perfect.I have 2 more problems(sorry!).
1. I made chapters for the 1st VCD and it worked fine,when I tried to make chapters for the second VCD it failed saying the mpg is not big enough.
2.When I tried to burn off the files it said my Cd writer was not supported (Zipcdr drive),any ideas/help to alernative software?I don't have nero.
Thanks once again.
Marlon Brando -
Glad to hear the DVDx problem is now solved, regarding your questions, how big is the second MPG file ?
Do you have access to: BlindWrite Suite / CDRWin / FireBurner ?Email me for faster replies!
Best Regards,
Sefy Levy,
The second MPG file is 206,444 kb,bin format it is 2,279.I have both those programs on a disc somewhere,which is better to use?
Thanks,
JJ -
The file sounds big enough to contain chapters, so the question is, how far apart are the chapters for the second part, maybe it's too far and doesn't fit the second part of your movie.
I suggest you first try CDRWin and then BlindWrite Suite.Email me for faster replies!
Best Regards,
Sefy Levy,
Blu Ray missing some scenes
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 7th Jun 2011, 02:23 -
Ripping my DVDs, taking out scenes and joining them
By theofile in forum DVD RippingReplies: 1Last Post: 9th Mar 2010, 15:14 -
DVD Ripping and Missing Scenes
By dimpayne in forum Newbie / General discussionsReplies: 11Last Post: 6th Dec 2007, 12:24 -
scenes missing from store-bought movies
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 15:53 -
2 DVDs of same film run different lengths but no missing scenes
By headless chicken in forum MacReplies: 2Last Post: 27th Sep 2007, 18:20
