I'm a newbie.. I try to encode mpeg1 using TMPengc. The source file is 567x304 divx format, i think. I play it under windows media player, the quality was very good. so i decided to burn it as VCD. i manage to get the file created, but no sounds at all.
Also, the vcd format i have are not good as the source, is there a way to make it same quality, i mean the picture ?
and I have some avi file that can't play on windows media player.. why ?
thank you so much
Results 1 to 1 of 1
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
How to add watermark to VCD without Re-Encoding?
By shebi in forum Authoring (VCD/SVCD)Replies: 25Last Post: 26th Apr 2009, 09:26 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
