  1. I have a strange problem with MPEG-2 remuxing in BBMpeg. When I am trying to burn the resulting file using VCDEasy it gives me numerous "Strange (possibly non-compliant) user data" and "unknown user data" warnings and the resulting XSVCD does not play at all. If I burn the original file, i.e. created by TMPGEnc and before demuxing/remuxing, VCDEasy gives me only one such warning and the resulting disc plays just fine. I am using TMPGenc to demux and BBMpeg with SVCD/VBR/Add scan offsets/Timestamps:all frames/Write program end code settings. BBMpeg does not give any errors. What am I doing wrong? Thanks in advance for any info.
  2. sounds like the way I do it... the only thing I may suggest is to zero out the forced mux rate and let BBMpeg use max. I hope this may help... not sure if it will...
    also... maybe try a dif. burner proggy... maybe nero (if its not compliant make sure and uncheck Create Standard Compliant CD in nero)
    peace,
    IgGy
  3. I set the mux rate to zero. Same problem as before. Will try Nero, although the idea of using VCDEasy was that it supports chapters.
  4. Plz post video info. det problem might be there
    frotsen
  5. The video is 352x576 25 fps MPEG-2 interlaced, variable bitrate.
