For some reason when I convert a 1hr-58min Divx3 movie to SVCD using TMPGE,it comes out as 2hrs-3min???
I'm using the standard SVCD template on a NTSC Film using the bitrate calculator to fit on 2 cd's.
(I should also add that when I extract the audio as a WAV it stays at 1hr-58min)
Can anyone help?
yes I rencoded some rips I made using tmpgenec and A bitrate calc it said the file should be 680mb but after rencoding it was still the original length then I'm not sure why but I simple remultiplexed it and Bingo 680mb so try remultiplexit and name it another file and compare sizes see if this works for you
Video length Automatically increase after encoding
By darkstonecold in forum Video ConversionReplies: 1Last Post: 22nd Nov 2011, 21:53 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
HD Coversion
By Stevo1975 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Feb 2010, 17:07 -
how to keep 4:3 on coversion
By wingfan in forum Video ConversionReplies: 10Last Post: 18th Dec 2008, 08:02 -
Coversion Quality
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 10th Jun 2007, 11:01
