Hello, is it possible to use only above applications ie Premiere and CCE 2.64 plugin (not stand alone program, no TMPGEnc, no Virtual Dub no other prog) to produce SVCD with VBR rather than CBR. If yes, please explain me how. When I tried to use plugin in premiere, it said you can't use to export audio with VBR mode. So, in order to export mpg file with audio I have to use CBR. Is it normal or something wrong with my settings. Thanks for any help
In VBR mode cce let you encode elementary streams only. You have to make sure, that you load a 480x480 / 576 resolution source and you have to multiplex afterwards, e.g. with bbMPEG.
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 03:53 -
VBR in CCE SP2 creates playback time error leading to no audio
By Albedo in forum Video ConversionReplies: 22Last Post: 11th Jun 2008, 16:23 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 18:30 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 20th Feb 2008, 00:33 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 10:04
