Wondering why are there not more tools supporting distributed encoding (video only; since for audio encoding the network and communication overhead is probably not worth the effort) I'm thinking of what is needed:
- a client<>server program which allows to transfer messages and files (using AllJoyn would be nice)
- a server which splits video by key frames (can be done through ffmpeg and its 'segment' option)
- sever then sends a part to each client for reencoding (together with the settings to use) and waits for the client to send back the reencoded part
- clients:
- get a chunk and reencode it (using the settings the get with the file)
- send the rencoded chunk back to the server
- signal the server that they are ready to take another chunk
- one the server has all reencoded chunks it merges them should also be possible using mkvmerge for example
Problems I see:
a. vfr content
b. embedding subtitle
but leaving those two cases out, where else do you see problems?
I know there is RipBot264, but it's Windows only and from what I know it always splits after a fixed frame count.
Splitting at key frames or scene changes (more tricky but should also be possible; more complicated chunking, and sending start&end frames).
Cu Selur
Ps.: Not sure whether I myself will implement this in Hybrid, write a separate tool or write a tool at all, just thought it might be a good thing to brainstrom about.![]()
users currently on my ignore list: deadrats, Stears555, marcorocchini -
You are right, open gop would potentially create really large chunks,.. (not sure whether ffmpegs segment option would properly split for open gops,..)
Yeah, like one big chunk depending on the stream.
It doesn't.
RipBot uses this "strange" AviSynth via Windows file sharing solution to avoid these troubles.
Maybe you can use -ss and include a few extra GOPs at the cut points for security so it works with 99.9% of streams. -
Okay, as a fallback the server could reencode to a lossless format with closed gops, but that would increase network load and general processing quite a bit.
Another option would be to making sure that all clients can access the source through something like 'AVFS'.
That would:
a. stress the network connection to the server (bad)
b. would make it easier to handle subtitles and vfr (good)
c. would put all the decoding stress on the server (bad)
Both don't that good,...users currently on my ignore list: deadrats, Stears555, marcorocchini
Ripbot264 Distributed Encoding Guide?
By tommy2010 in forum Video ConversionReplies: 24Last Post: 4th Oct 2022, 18:28 -
[Seeking Devs] Cloud Transcode: Distributed FFMpeg in the Cloud
By koxon in forum ProgrammingReplies: 31Last Post: 24th Feb 2017, 03:24 -
Add and or remove black frames from MKV (h.264) file without re-rencoding?
By Krawhitham in forum EditingReplies: 1Last Post: 12th Sep 2015, 02:39 -
By koxon in forum Video ConversionReplies: 2Last Post: 9th Mar 2014, 21:41
