Can you help, I ordered a DVD and it says it needs a regional code , how do I play it and what is my code ?
You're in region 2. Here's more info:
http://www.ebay.com/gds/DVD-REGION-CODES-EXPLAINED-What-is-a-REGION-CODE-/10000000004641793/g.html -
Thankyou for your help !
what can I do if I have a dvd from america and am based in Europe, region 2 ? is there anything I can do at all?Last edited by chrisstraw; 6th Jan 2018 at 16:57. Reason: hadnt finished it
Most DVD/Bluray players are set/locked to the region in which they are sold, region 2 for the UK. You can either try to set your DVD/Bluray player to be a multi-region player, search in the DVD hacks section of this website for your player to see if one is available, but many cannot be changed or have had new software installed to stop current hacks working.
If that isn't an option you could try 'ripping' the DVD on your PC to remove the copy and region protection and reburn to a blank DVD so you can play it in your current player. I should point out that this is currently illegal in the UK as you would be breaking the copy protection so you can be your own judge as to whether you want to do that!
If that isn't an option you could either buy a multi-region player, usually more expensive and harder to find than a regular player, or see if you can exchange the DVD with wherever you bought it for a region 2 DVD instead.
Reset Regional Code for Philips CED750 DVD player
By Eddie Wentzel in forum Newbie / General discussionsReplies: 7Last Post: 9th Sep 2016, 14:13 -
Regional coding
By Rex Crook in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Jun 2016, 15:26 -
DVD regional hack for Panasonic DMP-BDT160?
By raydonovan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jan 2016, 11:18 -
Change regional settings
By Eseniloc in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Jan 2016, 16:41 -
DVD Player regional codes
By jazzman25 in forum Newbie / General discussionsReplies: 7Last Post: 1st Apr 2013, 15:06
