Hey guys help, here is the problem: I have an Xvid/AC3 .avi. First I have removed the AC3 file from the container and then replaced it with an AC3 from outside the container (same characteristics, just replaced one audio track of the same film with another audio track which was only available as an outside source). The original AC3 audio works fine when film is played in the MPC, and also the outside AC3 file works fine when played just as an outside AC3 file in the same MPC. BUT after I have removed the original AC3 from the container and replaced it with the second file there is no sound anymore, the second AC3 file won't play anymore when inside the container and when played as part of the film! What am I doing wrong?
Which software are you using for this process? Try AVI Mux GUI and VirtualDub.
Post MediaInfo of all files. -
What about use MKVtoolnix for alteration of audio. Open your file in Mkvtoolnix, add ac3 you want to this and uncheck unwanted track. Start multiplexing. Then open this file in Avidemux. Video copy, audio copy and output format to AVI.
Can't this be a better way?
Bernix -
Glad it worked!
Why not worked with virtualdub really don't know, but as sneaker wrote probably if you check mediainfo of file that is supposed to have AC3 and that doesn't plays it, can helps to understand why.
Bernix -
Well can't do it anymore anyway, shift-deleted the now redundant original AC3 lol
How do you remux aac and ac3 from mkv to mp4? winff won't keep both
By yoda313 in forum Video ConversionReplies: 4Last Post: 11th Jan 2014, 19:00 -
Trying to demux MKV file and remux as AVI with hardcode subs
By medicated in forum Video ConversionReplies: 24Last Post: 2nd Aug 2013, 20:48 -
Bd mkv remux Plays without sound in power DVD!
By botdvd in forum Video ConversionReplies: 2Last Post: 22nd May 2013, 02:05 -
remux avi dx50 to mp4
By HWgeek in forum Video ConversionReplies: 20Last Post: 27th Apr 2013, 05:52 -
How to remux AVI with 2 audio streams to MP4?
By wallywalters in forum Video ConversionReplies: 2Last Post: 12th Feb 2013, 04:40
