I have been using MPC-BE since i can remember, and i cant trade it for anything. Is there a way to get it to run on Linux or an Android Device. I have been using a laptop for my TV in my living room, but i'm thinking of switching to a smaller device or an Android TV box, but i cant get around to not using MPC
Results 1 to 12 of 12
try looking here - https://www.videohelp.com/software/sections/linux-video-tools
Well i use DXVA since its an old laptop (circa 2011) but mostly i have mapped key bindings to my liking and use a remote controller to communicate with it and found that it does everything i need. Like i can set sub delay with a key, i can define in milisecs how far a small medium and large time jump is, i can scroll to next subtitle and audio if needed, i have set a key to add the exact time of a frame to favorites in case i want to revisit, i can capture a screen in uncompressed quality, and moreover i generally like the interface and osd
Actually in my book that means it doesn't work. WIne is actually a ridiculous hack that completely fails with most apps, and the ones that do work often do so poorly.
It would help a lot if the OP provided some details, especially which Linux distro is used, which makes a difference.
There was some sort of a Linux fork of MPC years ago but it hasn't been maintained since 2011. And, since there is almost no backwards compatibility in Linux, it'd be useless.
This question has been asked by Linux noobs on many forums and the answer is always the same in the end. There are many good music players in Linux. Choose one. -
I havent decided on a distro, but im flexible on that as soon as i get the player down. Im not looking for music player, but a video player. On my previous post, i state exactly the functions that i find unique that suited me over the years offered by mpc. In case i can get all of them, no exceptions with vlc or another player, im down for that
If you're new to Linux the only ones that are really good for beginners are Ubuntu and Mint. I use Mint but I actually recommend Ubuntu to noobs ... it has the best tech support sites, and you'll need them. There are other distros like Debian or Arch that have great support bit they're intended for experts and don't hold noob hands.
Mistyped that ... there are also many good multimedia players. I use SMplayer as my default for videos (I did in Windows too). Have VLC but rarely use it ... IMO it's perhaps the most over rated app. It's a good music player though. For music I use Audacious and Clementine.Im not looking for music player, but a video player.
I saw that, but you aren't going to get exactly the same thing in Linux. I've seen this sort of question in Linux forums for years. Old news. And the answer's always the same.On my previous post, i state exactly the functions that i find unique that suited me over the years offered by mpc. In case i can get all of them, no exceptions with vlc or another player, im down for that
A lot of Linux noobs seem to think they're going to be getting a free version of WIndows. They aren't, it's different. -
You may want to take a look at mpc-qt.
https://github.com/cmdrkotori/mpc-qt
windowed borderless like vlc player for media player classic?
By Crea in forum Software PlayingReplies: 4Last Post: 21st Aug 2015, 14:11 -
By Crea in forum Video ConversionReplies: 1Last Post: 21st Aug 2015, 12:18 -
Playing forced subtitles - Windows Media Player/Media Player Classic
By pizzaboyUK in forum SubtitleReplies: 3Last Post: 18th Mar 2015, 01:57 -
media player classic annoyance
By timeless in forum Software PlayingReplies: 0Last Post: 22nd Dec 2014, 05:20 -
Media Player Classic No Sound
By jrank001 in forum Software PlayingReplies: 19Last Post: 20th Jun 2014, 04:07
