Hi guys,
I use Subtitle Edit and need to make EBU STL subtitles in Russian. I faced a problem with encoding. After opening the saved file, all text in Cyrillic turned into rows of question marks. I tried using both Unicode and 1251 Cyrillic but with no result. I don`t face such an issue with other formats (srt for example) but the file must be in EBU STL.
Is there a way to convert it back into Russian and avoid the problem in future?
In EBU STL export window, try with "Character table" set to "Latin/Cyrillic". Hope this helps.
Thanks! It helped together with changing Code page number from 437 (English) to 866 (Russian).
How to translate Cyrillic characters?
By Patapin in forum SubtitleReplies: 3Last Post: 14th Sep 2016, 10:34 -
x264vfw - problem with encoding
By Colek in forum Video ConversionReplies: 3Last Post: 13th Sep 2015, 04:19 -
5.1 AC3 encoding problem
By chazz spacey in forum AudioReplies: 12Last Post: 28th Dec 2014, 10:24 -
352x576 re-encoding problem
By lascetic in forum Video ConversionReplies: 23Last Post: 15th Nov 2013, 12:49 -
Reading a Windows Cyrillic file in Notepad or Wordpad - Subtitling Purposes
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 30th Jun 2013, 12:35
