Hello,
Is there any solution to this problem ? How to find the missed frames by this program , those short lines and sometimes there are portion bigger of text that he is missing when I run the search ?
If I want to ocr a movie with runtime of 86 minutes the program is missing over 80 de lines or more from that subtitle.
Is there another program or a script who even it will take a long time to do it , do this job perfectly ?
Or how do you guys who use this program find those missing lines quickly ?
It's true that VideoSubFinder cannot recognize some lines. Usually this happens when a line is followed by a line of similar position and size or something like that, so the second line is not recognized.
I tried using different values in the settings but nothing worked so I looked at the settings file "general.cfg" in the "settings" folder and tried changing the values there.
I found out that when changing the value of "vedges_points_line_error" variable to something like 0.20 instead of the default 0.35 then it would find the missing subtitles.
In summary, in the file "/settings/general.cfg"
changing
"vedges_points_line_error = 0.35"
to
"vedges_points_line_error = 0.20"
worked for me
If 0.20 does not work for you maybe you'll have to lower this value even more.
But I think it's safe to say that the reason for the missing lines is this variable in the settings file. -
Ok. I will give it try and let you know if it worked.
What I'm doing now is finding those missing lines in Subtitle Workshop , I set the playback speed at 300% and check between pauses. -
I see. For my hardsubbed videos changing this variable "vedges_points_line_error" was enough to give me almost perfect results. Maybe the hardsubs in your videos cannot be recognized due to some other variable that has to do with the size or the colors of the text. It would be great to have a manual for these variables but you can try changing the values of the variables in settings file one at a time and see if it fixes the problem.
Using AVIAddXSubs to add subs to divx for PS3, subs cutting out
By ProfN in forum SubtitleReplies: 1Last Post: 23rd Dec 2016, 09:54 -
Is it possible to make subs for DVD (check the terms on post)
By TonyTheGreek in forum SubtitleReplies: 3Last Post: 5th May 2016, 02:41 -
Adding original subs to extended scenes where translated subs missing
By SidDan in forum SubtitleReplies: 2Last Post: 6th Aug 2015, 04:57 -
Nero 7 - "Make DVD" option missing?
By aelfheah in forum Authoring (DVD)Replies: 7Last Post: 19th Jan 2015, 16:49 -
How to make format factory detect subs?
By raphael512 in forum Video ConversionReplies: 2Last Post: 18th May 2014, 04:20
