OK, I have this 1080p video which has DTS standard and HD master audio only, so I've used Handbrake to generate a 480p copy (for speed) with the same frame-rate and add AC3 audio using the DTS audio as a template. Then I extracted the AC3 using MKVExtract, so now I have an 'audio.AC3' file. I then open MKVToolNix GUI to mux the AC3 file into the original 1080p video, and when I drag and drop the AC3 file this dialog pops up wanting me to choose my intention, but I'm not sure what each of the options mean. See image below:
I'd like to not only know, which I need to choose so no matter what player I use to watch the video (smartTV, Computer or DVD/Blu-ray hardware player) the video and audio sync properly and they use the appropriate audio they're capable of, but also the scenarios that all the other options are for.
TIA.
P.S. Of course anything useful would be highly appreciated.
Happy New Year!
From high up here above earth, it's obvious our perspective is limited.
Choose the first for adding additional files/tracks (e.g. .ac3) to an existing mkv.
1. option: add to existing file/settings/tab
2. option: create new file/tab (with only .ac3 audio)
3. option: create new file/tab for every file you drag&drop (in case you marked multiple files)
4. option: append, i.e. not add a track but play them in order. E.g. "A.MKV" is 30 minutes and "B.MKV" is also 30 minutes, then you get a 60 minutes file.
5. option: append but do as if files were originally one file only split on the binary level (only for certain kind of splitted files, e.g. VOB from DVD)
MKVtoolNIX GUI "Add file as additional part" suddenly stopped working
By fettsvett201 in forum EditingReplies: 1Last Post: 21st Mar 2017, 08:04 -
MKVtoolNix GUI "Files cannot be appended to themselves."
By fettsvett201 in forum EditingReplies: 4Last Post: 14th Mar 2017, 19:36 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
convert three files : ".au" ".temp_audio" " .temp_video" files to mp4
By correx in forum Video ConversionReplies: 4Last Post: 20th Nov 2014, 05:15 -
Adding on "surround sound" to MKV files
By theproman23 in forum AudioReplies: 1Last Post: 18th Apr 2013, 12:22
