Results 1 to 12 of 12
  1. What is the correct version of Nero AAC Decoder I need ? It would be much easier if I can just somehow convert this AAC to AC3 without losing anything but I don't think thats possible
  2. But I have no idea what to do after that ? AudioMuxer still does not detect it
  3. Can you show the error message? I don't use AudioMuxer myself.
    That said I misremembered. eac3to does use the files I linked for AAC encoding, not decoding. The Nero thing for decoding is a bit more complicated: https://forum.doom9.org/showpost.php?p=1801808&postcount=14184
    (Assuming AudioMuxer tries to use eac3to for that job at all - I don't know.)
    IMHO using eac3to for AAC decoding is too complicated because of that. I would use a different software for AAC decoding (e.g. ffmpeg or a GUI like Xmedia Recode. You can set video to copy and audio to AC3).
  4. What I am trying to do is extract multi channel waves from 6 / 8 channel AAC. AudioMuxer for me seems like it would be easiest. Im really bad with Command Line stuff. If I could just convert AAC to AC3 & keep everything that would be easier but this task (simply converting) is not easy at all it seems
  5. !!!!!!!!!!!!!!!!!!!!!!!
  6. https://image.ibb.co/nfsZcR/Screenshot_55.png
  7. NeroAacDec can only open AAC audio in an mp4 container (in mp4 container elements are often called "boxes"). So it won't work this way.
    Try a different tool. (e.g. Xmedia Recode. Open the file, choose format "AC3" or "WAV", add job to queue and start.)
  8. Xmedia Recode makes me convert the audio therefore I lose the multi channels no copy option
  9. If you go to the "Audio" tab you can select 5.1 channels.
    But it seems Xmedia doesn't expose the 7.1 option. I didn't know this. But if your end goal is AC3 it doesn't matter because AC3 doesn't support more than 5.1 channels.
  10. Ah so yep if I can get Audio Muxer working than I can just extract right from the AAC
