I am getting the following error when opening rebox.net:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Configuration system failed to initialize.
I have placed at the end of my post, further details of this error.
I am on Windows 10 (have been for some time, have a PC with good specs) and this started happening after a recent Windows update.
I have chosen both Continue and Quit, and can't proceed. Have also restarted the PC several times, and have uninstalled and downloaded and reinstalled rebox.net with no improvement.
Would really appreciate help in fixing this, as I'm not happy with other mkv to mp4 alternatives like VLC.
Thanks,
Richard
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: '.', hexadecimal value 0x00, is an invalid character. Line 14, position 1. (C:\Users\Richard & Kim\AppData\Local\clone.AD\rebox.NET.exe_Url_1c5ec 4vcuxhufq5flwho02hff52ij4o5\2.9.9.3\user.config line 14) ---> System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 14, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
at System.Xml.XmlTextReaderImpl.ParseText()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Skip()
at System.Configuration.XmlUtil.StrictSkipToNextEleme nt(ExceptionAction action)
at System.Configuration.BaseConfigurationRecord.ScanS ectionsRecursive(XmlUtil xmlUtil, String parentConfigKey, Boolean inLocation, String locationSubPath, OverrideModeSetting overrideMode, Boolean skipInChildApps)
at System.Configuration.BaseConfigurationRecord.ScanS ections(XmlUtil xmlUtil)
at System.Configuration.BaseConfigurationRecord.InitC onfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.Thr owIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.Throw IfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.ClientConfigurationSystem.OnC onfigRemoved(Object sender, InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.O nConfigRemoved(InternalConfigEventArgs e)
at System.Configuration.Internal.InternalConfigRoot.R emoveConfigImpl(String configPath, BaseConfigurationRecord configRecord)
at System.Configuration.BaseConfigurationRecord.GetSe ctionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSe ction(String configKey)
at System.Configuration.ConfigurationManager.GetSecti on(String sectionName)
at System.Configuration.ClientSettingsStore.ReadSetti ngs(String sectionName, Boolean isUserScoped)
at System.Configuration.LocalFileSettingsProvider.Get PropertyValues(SettingsContext context, SettingsPropertyCollection properties)
at System.Configuration.SettingsBase.GetPropertiesFro mProvider(SettingsProvider provider)
at System.Configuration.SettingsBase.GetPropertyValue ByName(String propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPr opertyValue(String propertyName)
at System.Configuration.ApplicationSettingsBase.get_I tem(String propertyName)
at rebox.NET.My.MySettings.get_IN_FOLDER()
at rebox.NET.FO_MAIN.MAIN_SETUP_IO()
at rebox.NET.FO_MAIN.FO_MAIN_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2600.0 built by: NET471REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
rebox.NET
Assembly Version: 2.9.9.3
Win32 Version: 2.9.9.3
CodeBase: file:///C:/Program%20Files%20(x86)/clone.AD/rebox.NET/rebox.NET.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Results 1 to 1 of 1
Rebox full version
By Renfris in forum Video ConversionReplies: 1Last Post: 20th Dec 2017, 02:38 -
FFMpeg HTTP error 403 Forbidden with akamaihd.net
By theshaft in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jan 2016, 19:43 -
Recommend me an h264 mp4 error scanning program
By DRP in forum Software PlayingReplies: 5Last Post: 22nd Nov 2015, 17:39 -
daum.net potplayer vs dvbsupport.net potplayer
By Binyul in forum Software PlayingReplies: 1Last Post: 12th May 2014, 09:45 -
Rebox.net & clean Windows 8.1 install
By greenmile in forum Video ConversionReplies: 5Last Post: 18th Nov 2013, 17:15
