Hi!
I am new to encoding, but already used Handjob and Moulders x264 succesfully for more than year. Now I am tring to improve quality of my mkv's by changing params. This is somehow exhaustive in GUI if you test same file again and again. I tried to write a command on windows powershell which could be used to create mkv from my avs file. Then I planned to build Python script with that cmd which changes parameters I want.
I saw in Moulders x264 event log that it sends following commands:
I tried to build my own commands based on above in windows power shell:Code:"C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\avs2yuv_x86.exe" E:\movies\movie1.avs - "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\x264_8bit_x86.exe" --crf 16.0 --preset placebo --profile high --aq-mode 2 --merange 32 --sar 16:9 --output "E:\movies\test_movie.mkv" --frames 600 --demuxer y4m --stdin y4m -
but it results in memory exception System.OutOfMemoryException, but I sam process manager and there is lot of free memory.Code:./avs2yuv_x86.exe E:\movies\movie1.avs - | ./x264_8bit_x86.exe --crf 16.0 --preset placebo --profile high --aq-mode 2 --merange 32 --sar 16:9 --output "E:\movies\test_movie.mkv" --frames 600 --demuxer y4m --stdin y4m -
When I execute the same in cmd.exe I get error for missing MSVCR71.dll (although I added this to system32).
I must be doing something wrong, probably I miss the basics. Tried to look for answers or some tutorials on that for 3 days but I am only getting more frustrated. Tutorials are usually details and I cant move on.
Greets,
amonowy
Results 1 to 9 of 9
Is it a typo or did you forgot to actually put input from avs2yuv_x86.exe? That missing "-" at the end of command line.
x264.exe can load avs script directly:
x264.exe --crf 16.0 --preset placebo --profile high --aq-mode 2 --merange 32 --sar 16:9 --frames 600 --output "E:\movies\test_movie.mkv" "E:\movies\movie1.avs"
you have not set buffers in your command line, do not leave it default, by including them, you sort of select max. bit rates, and because of crf 16 it could be very high
--vbv-maxrate 40000 --vbv-bufsize 40000
unless you do not care about max. bitratesLast edited by _Al_; 4th Jan 2018 at 16:09.
Thanks for the reply, I did it the way you proposed and it encoded well! Good starting point to excel my encode skills
that value --sar 16:9 is kind of weird, that value does not suppose to be ratio between width and height
if it is movie it should be --sar 1:1 , which is default, you do not have to set it, for whatever movie aspect ratio (1920x800, 1920x1080) because it is square pixel,
--sar x:y is set only in case if video is anamorphic, like camcorder HDV videos, VHS, DV , DVD:
Code:if %ar%==4:3 if %h%==480 if %w%==720 (set sar=8:9) if %ar%==4:3 if %h%==576 if %w%==720 (set sar=16:15) if %ar%==16:9 if %h%==480 if %w%==720 (set sar=32:27) if %ar%==16:9 if %h%==576 if %w%==720 (set sar=64:45) if %ar%==4:3 if %h%==480 if %w%==704 (set sar=10:11) if %ar%==4:3 if %h%==576 if %w%==704 (set sar=12:11) if %ar%==16:9 if %h%==480 if %w%==704 (set sar=40:33) if %ar%==16:9 if %h%==576 if %w%==704 (set sar=16:11) if %ar%==16:9 if %h%==1080 if %w%==1440 (set sar=4:3)
if --sar 16:9 works on screen at the end, you are getting correct proportions on screen, that means, that something went wrong along the way, there is a better way how to sort it out, you'd need to provide more details.
Convert Videos for Playing on Chromecast - PowerShell script
By V1de0Luvr in forum Video ConversionReplies: 2Last Post: 30th Jun 2016, 09:37 -
AVS to MKV?
By AlanHK in forum Video ConversionReplies: 3Last Post: 12th May 2015, 15:57 -
Create .avs files for MP4 and MKV to open in VirtualDub
By A2000 in forum Video ConversionReplies: 3Last Post: 24th Jan 2015, 08:59 -
Footage looks fine as MKV and AVS, but glitches in Vegas
By badmojorayman in forum EditingReplies: 2Last Post: 16th May 2014, 09:35 -
Problem Encoding Mkv to Mp4 with Xvid4PSP 5.10
By duplakappa in forum Video ConversionReplies: 4Last Post: 2nd May 2014, 17:07
