I am using mpv https://mpv.io/manual/stable/
but how on earth do you save the video you are altering
Probably this https://mpv.io/manual/stable/#configuration-files
It seems to me too complicated for everyday using....
Bernix -
follow this https://pastebin.com/5B8w0ZLk
it is nicely explained with examples, I have mpv portable and I have mpv.conf in portable_config directory (located in the same directory as mpv.exe is)
then:
mpv whateverin.avi -o new.mp4
works, that mp4 is created
EDIT: that config is not set up correctly like that, it is just some defaults, so investigate why or just setup x264 variables in that command lineLast edited by _Al_; 3rd Jan 2018 at 14:27.
Thanks all but I still have not had a reply on how to save any alterations you have done to a video, plus like Bernix said, its a bit too complicated also for me too, so will give up on it. Im no good at all this scripting stuff, too old for all that.
Saving current frame w/ Potplayer + madVR, not saving madVR effects
By LJay in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2017, 15:14 -
Mpv configuration
By hisaishi in forum Software PlayingReplies: 4Last Post: 6th Jun 2017, 17:17 -
VO in mpv?
By fighuass in forum Software PlayingReplies: 1Last Post: 26th Feb 2017, 07:58 -
How to use mpv? (on Windows)
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 14th Jan 2017, 06:04 -
mpv playlists
By steve6 in forum Software PlayingReplies: 0Last Post: 19th Jun 2016, 06:45
