Can someone help me with this. You can reach me at m2master@yahoo.com
Or could someone provide me with a link to a guide
-Thanks
Results 1 to 9 of 9
um....what is DCD? is that a typo and u meant DVD or is DCD some kind of format?
Do you mean DVCD (double vcd)? it is a very popular format in China...
I know about a software that can open DVCD, called herosoft 2000, but I dont have it... site is chinese language...
Fredİ -
when i try to convert the mpeg to .bin in EasyVCD it says that i dont have ASPI drivers? What should i do? I am running xp
Damnit i got a driver from the first link you gave, installed it and its still not working. I tried Adaptecs drivers and they dont work. Can someone leave DETAILED instructions on how to get the aspi drivers to work SPECIFICALLY ON AN XP BOX
I installed VCDEasy couple of days ago to my pc running XP. I recall the apsi was disable by default in case it doesn't work for your system.
Take a look at the "how to burn vcd/svcd using vcdeasy" document .
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
