Hello Folks. Wondering if anyone can help me figure out why the following files are not compliant. Below I have several versions of the original file which is listed first
1--- Original File
Complete name : Cesktop\Spence\15. Javier Castro.ts
Format : MPEG-TS
File size : 1.10 GiB
Duration : 24mn 34s
Overall bit rate : 6 420 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 24mn 34s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 24mn 34s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Changed File 1
Complete name : C:\Desktop\Spence\15. Javier Castro SAMPLE (02).m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 107 MiB
Duration : 2mn 17s
Overall bit rate : 6 541 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2mn 17s
Bit rate : 6 145 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.111
Stream size : 101 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 2mn 17s
Bit rate mode : Constant
Bit rate : 128 Kbps
Stream size : 2.10 MiB (2%)
Language : English
				Results 1 to 10 of 10
	Yes, I am sorry I was meaning for BD. What information might help me get more help and what program can I get that information with?
	You would need a h264 stream analyzer (expensive, such as elecard or codec visa) , or use h264_parse (free and commandline, but it can be difficult to interpret). You also have to read about BD stream compliance
 But what are you going to do with the information ? ie. so what ? If it's non compliant, you have to re-encode anyways
	lol...@ "so what?"
 It's a question I am asking so I can get more understanding of what is and is not compliant. I guess the simplest answer is "cause I wanna know." But, with that knowledge, I would (hopefully) be able to create BDs with great quality, minimal quality loss from original source and minimal time spent in transcoding.
 I started with some files (mpeg2 from DVD) about 10 or so of them. When I put a few into Encore, it says no transcode required. The others do. Encore seems to take forever to transcode. I thought I would be able to use videoredo but it doesn't look like I have much use for it anymore with using premiere and encore.
 I do suppose the question has become moot over the last few hours as I have figured out the setting to make any video "compliant" through Premiere. I don't have to figure out what is right or wrong now I can just throw it in but I may spend some time with that h264_parse thing and see what I can come up with.
 Thanks.
	ok here is some info . It's specific to x264, but many of the concepts are the same regardless of which AVC encoder is used
 https://forum.doom9.org/showthread.php?t=154533
 MPEG2 from authored DVD will always be complaint for SD blu-ray . So something is up with the "others"I started with some files (mpeg2 from DVD) about 10 or so of them. When I put a few into Encore, it says no transcode required. The others do.
 Right, encode with the "blu-ray" settingI do suppose the question has become moot over the last few hours as I have figured out the setting to make any video "compliant" through Premiere.
	Also realize that Encore ignores large parts of DVD/BD specs. So even when assets are 100% compliant, Encore will balk. For that reason, I've said the software sucks for 10+ years now. Want my help? Ask here! (not via PM!)
	For BD, its actually the other way around - It's not stringent enough. It lets stuff pass through that fail on official BD verifiers
  Rip DVD, no transcode, files created by chapter range (TV show, seasons)By Nerevarine in forum DVD RippingReplies: 4Last Post: 18th Mar 2015, 17:44
  Converting Pillaboxed SD AVC HD Files to DVD Compliant WidescreenBy Tom Saurus in forum Video ConversionReplies: 5Last Post: 10th Jan 2014, 10:31
  Digital8 avi files to DVD compliantBy reptile69 in forum Video ConversionReplies: 15Last Post: 6th Dec 2013, 00:11
  How best to prep files so iDVD doesn't take 4.5 HOURS to transcode them?By dunkmeister in forum MacReplies: 13Last Post: 26th Aug 2013, 13:54
  MPEG Streamclip to join files but not transcode?By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 13:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
