Hello,
I want to use a profile with the settings below:
- Can i encode it with VIDCODER like the encode-config below or not?
- i know, how to create a profile in Vidcoder but i have a problem to recreate the config below in vidcoder cause not every option is named like in the config below.
Please explain to me, how i can create a profile like this. Thank you. I prefer Vidcoder instead of Handbrake, cause Vidcoder is for me more transparent with its options. I have no experiences with other encoding-software like handbrake + vidcoder.
Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, RefFrames : 11 frames Codec ID : V_MPEG4/ISO/AVC Duration : 51 min 19 s Bit rate : 8 159 kb/s Width : 986 pixels Height : 720 pixels Display aspect ratio : 4:3 Original display aspect ratio : 1.370 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.479 Writing library : x264 core 148 r2597+53 5548565 t_mod_Custom [8-bit@all X86_64] Encoding settings : cabac=1 / ref=11 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.10:0.10 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=18,9 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=19.5000 / qcomp=0.70 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / ip_ratio=1.33 / pb_ratio=1.25 / aq=3:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
I suspect you could only replicate these by using CLI commands in Handbrake. https://handbrake.fr/docs/en/latest/cli/cli-guide.html
Multi-Format Disc Ripping - DVD or BluRay?
By SetoTitan in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2016, 05:40 -
What system resources are being used when ripping a DVD/BluRay disc?
By SetoTitan in forum DVD RippingReplies: 4Last Post: 10th Mar 2016, 10:36 -
Ripping Bluray disc by scaling bitrate
By zeusfriends in forum Blu-ray RippingReplies: 30Last Post: 4th Nov 2014, 13:23 -
I am having a problem ripping a bluray disc
By laserguy100 in forum Blu-ray RippingReplies: 2Last Post: 6th May 2014, 18:01 -
Copying & ripping my blu ray movie then burning it onto a blank bluray disc
By chris_2012 in forum Authoring (Blu-ray)Replies: 18Last Post: 22nd Mar 2013, 10:43
