Hello, I've just got RipBot and installed all required software it needs, but when i give it a video it loads the video to 100% and then gives me this error
"I don't know what 'erlace' means.
(C:\Temp\RipBot264temp\job1\getinfo.avs, line 2)"
here is the .avs file that ^ mentions, line 2 is erlace but what does this mean?
"video=DirectShowSource("D:\CLIPS [rendered]\clips 2 handbreak\ballista 2k death cine 1.avi",audio=false).ConvertToYV12(matrix="rec709")
erlace
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","F ramecount")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","F ramerate")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","A udioRate")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","A udioChannels")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","A udioLength")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","W idth")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","H eight")
WriteFile("C:\Temp\RipBot264temp\job1\info.txt","P ixelType")
Trim(0,-1)"
I'm not sure what erlace means or how to fix it, I'm trying to make the filesize for this video smaller so i can send it too my friend. (If it helps, clips frame rate is 600FPS and the file size is 4.31 GB)
Decoding error
By Stalker2400 in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2014, 18:18 -
RipBot Error
By Jake802 in forum Video ConversionReplies: 5Last Post: 5th Jun 2014, 07:24 -
Decoding Error
By UNiKMeTaLLiX in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2013, 03:25 -
Ripbot error Distibuted...
By damia in forum Blu-ray RippingReplies: 0Last Post: 26th Apr 2013, 21:21 -
Ripbot error..
By damia in forum ffmpegX general discussionReplies: 3Last Post: 24th Apr 2013, 10:15
